Was du brauchst
With the phone facing down, look at the bottom right side corner and there should be a groove. Use a plastic opening tool and lift up to remove outside cover.
Around the perimeter, there should be 10 2 mm T5 Torx screws. Take them out.
Remove the cover.
Remove speaker with standard tweezers to minimize damage, and replace.
Fast fertig!
Abschluss
