Zum Hauptinhalt wechseln
Asus Padfone X Mini Speaker Replacement
Was du brauchst
  1. Asus Padfone X Mini Speaker Replacement, Speaker: Schritt 1, Bild 1 von 1
    • With the phone facing down, look at the bottom right side corner and there should be a groove. Use a plastic opening tool and lift up to remove outside cover.
    • This is not the cover with the speaker attached.
  2. Asus Padfone X Mini Speaker Replacement: Schritt 2, Bild 1 von 1
    • Lift the battery out from the top of the device.
  3. Asus Padfone X Mini Speaker Replacement: Schritt 3, Bild 1 von 1
    • Around the perimeter, there should be 10 2 mm T5 Torx screws. Take them out.
    • Remove the cover.
  4. Asus Padfone X Mini Speaker Replacement: Schritt 4, Bild 1 von 1
    • Turn the cover over.
    • The speaker is attached to the inside of the cover and to the right of the camera hole.
  5. Asus Padfone X Mini Speaker Replacement: Schritt 5, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Remove speaker with standard tweezers to minimize damage, and replace.
Abschluss
Nicolette Carr
383 Reputation
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 6
Insgesamt: 155
