Zum Hauptinhalt wechseln
Asus Q200E-CT144H Fan Replacement
Was du brauchst
  1. Asus Q200E-CT144H Fan Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • To start, turn off the laptop and disconnect the power cable.
    • If the computer is on or plugged in, it could cause electric shock.
    • Flip the laptop over so the back panel is visible.
  2. Asus Q200E-CT144H Fan Replacement: Schritt 2, Bild 1 von 1
    • Remove the 9 screws holding the cover in place by taking a Phillips #00 Screwdriver and turning it counterclockwise.
  3. Asus Q200E-CT144H Fan Replacement: Schritt 3, Bild 1 von 2 Asus Q200E-CT144H Fan Replacement: Schritt 3, Bild 2 von 2
    • Use an iFixit opening tool to lift the back cover and remove it from the laptop.
  4. Asus Q200E-CT144H Fan Replacement, Battery: Schritt 4, Bild 1 von 2 Asus Q200E-CT144H Fan Replacement, Battery: Schritt 4, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Remove the battery connector by using tweezers to lift up on it.
  5. Asus Q200E-CT144H Fan Replacement: Schritt 5, Bild 1 von 2 Asus Q200E-CT144H Fan Replacement: Schritt 5, Bild 2 von 2
    • Remove the nine Phillips #00 screws that hold the battery in place.
    • There is one 9.2mm screw, four 4.7mm screws, and four 5.7mm screws.
  6. Asus Q200E-CT144H Fan Replacement: Schritt 6, Bild 1 von 2 Asus Q200E-CT144H Fan Replacement: Schritt 6, Bild 2 von 2
    • Remove the battery from the battery bay.
  7. Asus Q200E-CT144H Fan Replacement, Fan: Schritt 7, Bild 1 von 1
    • Remove the five 4.6mm Phillips #00 screws holding the fan in place.
  8. Asus Q200E-CT144H Fan Replacement: Schritt 8, Bild 1 von 1
    Kaufen
    • Disconnect the power bus with tweezers.
  9. Asus Q200E-CT144H Fan Replacement: Schritt 9, Bild 1 von 1
    • Lift and remove the fan from its housing.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 6
Insgesamt: 133
