Einleitung
If your laptop has experienced any physical damage to the screen, this can be a big problem considering that the screen is responsible for displaying information. Damage such as cracks can be dangerous if any of the loose glass from a shattered screen comes out of place. However, if there is no visible damage, there may be other issues afoot. Your laptop’s screen could blacked out due to lack of charge, possible overheating, or the screen just won’t work. If this is the case, you can use this guide to replace the laptop screen.
Was du brauchst
Turn off the laptop and disconnect the power cable.
Open the laptop and place it on a hard, flat surface with the screen facing up.
Take a metal spudger and insert it under the screen.
Slowly move the spudger across the length of the screen, separating the sections.
Pull apart the screen from the casing of the laptop.
Disconnect the power connector using tweezers.
