Einleitung
If you notice that your laptop’s audio transmission is distorted or there isn’t any sound coming from the computer altogether, there may be a problem with the speaker. Maybe you’ve tried everything in your power to troubleshoot the speakers and reached a dead end. In this case you can use this repair guide to help you replace the speakers in the laptop.
Was du brauchst
To start, turn off the laptop and disconnect the power cable.
Flip the laptop over so the back panel is visible.
Remove the 9 screws holding the cover in place by taking a Phillips #00 Screwdriver and turning it counterclockwise.
Use an iFixit opening tool to lift the back cover and remove it from the laptop.
Remove the right speaker from its housing.
Use tweezers to remove the black and white wire from its groove.
