Einleitung
How to remove the battery and replace it.
Was du brauchst
Place laptop upside down
Remove the cover by unscrewing the 10 screws highlighted in the picture
Use PH0 bit to remove the 1cm black screws
Unscrew the 5, 5mm screws with the PH0 bit
Lift up the battery connector, indicated in yellow
Remove the battery by lifting it in upward motion pulling it towards
Fast fertig!
Abschluss
