Zum Hauptinhalt wechseln
Asus Q304UA Hard Drive Replacement
Was du brauchst
  1. Asus Q304UA Hard Drive Replacement, Remove Bottom Cover: Schritt 1, Bild 1 von 1
    • Remove ten Phillips #0 screws that secure the plastic bottom cover to the chassis.
    • Six 9.6 mm screws
    • Four 4.6 mm screws
    • Throughout this guide, keep careful track of your screws so that each one goes back where it came from during reassembly. Installing a screw in the wrong place can cause permanent damage.
  2. Asus Q304UA Hard Drive Replacement: Schritt 2, Bild 1 von 3 Asus Q304UA Hard Drive Replacement: Schritt 2, Bild 2 von 3 Asus Q304UA Hard Drive Replacement: Schritt 2, Bild 3 von 3
    • Use a plastic pry tool to get in-between the bottom cover and the lower case assembly.
    • Be careful not separate the cover too violently or you will risk breaking the plastic clips that are on the bottom cover.
  3. Asus Q304UA Hard Drive Replacement, Disconnect the battery: Schritt 3, Bild 1 von 3 Asus Q304UA Hard Drive Replacement, Disconnect the battery: Schritt 3, Bild 2 von 3 Asus Q304UA Hard Drive Replacement, Disconnect the battery: Schritt 3, Bild 3 von 3
    • Push metal bracket away from battery connector.
    • Use a spudger to push the battery connection straight up.
    • If you pry too hard, or attempt to disconnect the battery with the metal bracket still in place, you risk pulling the connector off of the motherboard.
    • Make sure the computer is powered off before removing the battery.
  4. Asus Q304UA Hard Drive Replacement, Disconnect RF Cables: Schritt 4, Bild 1 von 3 Asus Q304UA Hard Drive Replacement, Disconnect RF Cables: Schritt 4, Bild 2 von 3 Asus Q304UA Hard Drive Replacement, Disconnect RF Cables: Schritt 4, Bild 3 von 3
    • Disconnect the Wifi/Bluetooth RF cables from the wireless card.
    • Pull the RF cables by the metal connector, not by the rubber shielding. This avoids damaging the connector and the cable.
  5. Asus Q304UA Hard Drive Replacement, Hard Drive Assembly: Schritt 5, Bild 1 von 2 Asus Q304UA Hard Drive Replacement, Hard Drive Assembly: Schritt 5, Bild 2 von 2
    • Pull straight up to disconnect the SATA combo cable from the motherboard.
  6. Asus Q304UA Hard Drive Replacement: Schritt 6, Bild 1 von 1
    • Remove three Phillips #0 that secure the hard drive bracket to the chassis, of the following lengths:
    • Two 2.3 mm screws
    • One 5.6 mm screw
  7. Asus Q304UA Hard Drive Replacement: Schritt 7, Bild 1 von 3 Asus Q304UA Hard Drive Replacement: Schritt 7, Bild 2 von 3 Asus Q304UA Hard Drive Replacement: Schritt 7, Bild 3 von 3
    • Tilt the drive up slightly by the connector
    • Remove the SATA combo connector
  8. Asus Q304UA Hard Drive Replacement: Schritt 8, Bild 1 von 2 Asus Q304UA Hard Drive Replacement: Schritt 8, Bild 2 von 2
    • De-route the SATA and RF cables from the side of the drive bay.
  9. Asus Q304UA Hard Drive Replacement: Schritt 9, Bild 1 von 1
    • Insert wisdom here.
  10. Asus Q304UA Hard Drive Replacement, Hard Drive Bracket Assembly: Schritt 10, Bild 1 von 2 Asus Q304UA Hard Drive Replacement, Hard Drive Bracket Assembly: Schritt 10, Bild 2 von 2
    • Remove the four Phillips #0 screws that secure the hard drive to the hard drive bracket.
    • Four 3.7 mm screws
  11. Asus Q304UA Hard Drive Replacement: Schritt 11, Bild 1 von 3 Asus Q304UA Hard Drive Replacement: Schritt 11, Bild 2 von 3 Asus Q304UA Hard Drive Replacement: Schritt 11, Bild 3 von 3
    • Peal back thermal cover.
    • Be careful not to tear the cover on the side of the drive as you peel it off.
  12. Asus Q304UA Hard Drive Replacement: Schritt 12, Bild 1 von 1
    • Remove drive from hard drive bracket.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
iHelpU.Tech
3.963 Reputation
5 Anleitungen geschrieben
iHelpU.tech Mitglied von iHelpU.tech
Business
2 Mitglieder
17 Anleitungen geschrieben
1 Kommentar zur Anleitung
This should be rated moderate. Easy is sliding out a drive bay on a old Dell laptop from 15 years ago. :)
Michael Maxson - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 15
Letzte 30 Tage: 44
Insgesamt: 5,580
