Was du brauchst
In diesem Schritt verwendetes Werkzeug:Magnetic Project Mat$19.95
Remove ten Phillips #0 screws that secure the plastic bottom cover to the chassis.
Six 9.6 mm screws
Four 4.6 mm screws
Use a plastic pry tool to get in-between the bottom cover and the lower case assembly.
Push metal bracket away from battery connector.
Use a spudger to push the battery connection straight up.
Remove the Phillips #0 screws that secure the battery to the lower case assembly
Three 4.7 mm screws.
Tilt battery up from the side closest to the motherboard
Pull the battery out of the chassis away from the two plastic retainers near the front of the laptop.
Disconnect the Wifi/Bluetooth RF cables from the wireless card.
Pull straight up to disconnect the SATA combo cable from the motherboard.
Remove three Phillips #0 that secure the hard drive bracket to the chassis, of the following lengths:
Two 2.3 mm screws
One 5.6 mm screw
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Use a spudger to flip up the retaining flap on the trackpad ribbon cable ZIP socket.
Use tweezers to pull the ribbon cable straight out of the ZIF socket.
Use the tip of a spudger to flip cup the retaining flap on the keyboard ribbon cable ZIF socket.
Use tweezers to remove the ribbon cable from the socket.
Use a spudger to flip up the retaining flap on the ribbon cable ZIP socket.
Use tweezers pull the ribbon cable out of the ZIF socket.
Use the tip of a spudger to flip up the retaining flap on the daughterboard ribbon cable ZIF socket on the motherboard.
Use tweezers to pull the ribbon cable away from the ZIF socket
Remove the four Phillips screws securing the logic board to the lower case assembly.
One 2.3 mm screw
Three 3.7 mm screws
Remove the three Phillips screws connecting the fan to the lower case assembly.
Three 4.6 mm screws
Remove the three Phillips screws securing the left hinge to the corner of the motherboard and lower case assembly.
Three 5.6 mm screws
Take a plastic pry tool and open the hinge about 75º-85º
Pull up on the corner of the motherboard and remove from the laptop.
**I am not responsible for any damages caused by any attempts at this repair. Use at your own risk.
5 weitere Personen haben diese Anleitung absolviert.
3 Kommentare zur Anleitung
Where is the CMOS battery located? For the life of me I can’t find it.
Ne meither and Asus didn’t know, either. IDK, my laptop wouldn’t hold BIOS settings or Time/Date. Asus told me it was a coin style CMOS battery on the back side of the motherboard. Called them back to report not finding it and then they refused to help because they accused me of intent to modify the unit, which they do not support. They suggested I send it to a service center on the east coast (I’m on the left coast) with an open limit on repair. All this for a laptop which has been out of warranty for 3 years. Eventually one tech suggested it might be built into the main battery but couldn’t say for sure.
Next time I will buy a Dell, Acer, HP or some other brand.
This laptop mother board does not have the usual CMOS/RTC coin cell battery. Apparently the settings (BIOS/UEFI) are maintained by the laptop battery itself. When I disconnected the laptop battery, the date/time reverts to the original factory date/time. HOWEVER .. there is a cable that contains the LCD connector, the SATA HDD connector based on that some indicate it is a “CMOS cable” which in all the years I’ve been working on computers, have never heard of. That is the same with all MacBook Pro laptops - no CMOS battery — it uses the laptop battery and NOT a CMOS coin cell battery.
