Zum Hauptinhalt wechseln
Asus Q325U Battery Replacement
Was du brauchst
  1. Asus Q325U Battery Replacement, Back Panel: Schritt 1, Bild 1 von 3 Asus Q325U Battery Replacement, Back Panel: Schritt 1, Bild 2 von 3 Asus Q325U Battery Replacement, Back Panel: Schritt 1, Bild 3 von 3
    • Remove the ten 5mm screws using a T5 Torx screwdriver.
  2. Asus Q325U Battery Replacement: Schritt 2, Bild 1 von 3 Asus Q325U Battery Replacement: Schritt 2, Bild 2 von 3 Asus Q325U Battery Replacement: Schritt 2, Bild 3 von 3
    • Lift the back panel upward using the suction tool.
  3. Asus Q325U Battery Replacement, Battery: Schritt 3, Bild 1 von 2 Asus Q325U Battery Replacement, Battery: Schritt 3, Bild 2 von 2
    • Remove the seven 5mm screws around the battery using a Phillips #00 screwdriver.
  4. Asus Q325U Battery Replacement: Schritt 4, Bild 1 von 2 Asus Q325U Battery Replacement: Schritt 4, Bild 2 von 2
    • Using a Phillips #000 screwdriver, remove the two 3mm screws on top of the orange battery connector.
  5. Asus Q325U Battery Replacement: Schritt 5, Bild 1 von 2 Asus Q325U Battery Replacement: Schritt 5, Bild 2 von 2
    • Lift the battery out from the laptop.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Flo Costa
235 Reputation
1 Anleitung geschrieben
Cal Poly, Team S19-G1, White Winter 2019 Mitglied von Cal Poly, Team S19-G1, White Winter 2019
CPSU-WHITE-W19S19G1
3 Mitglieder
6 Anleitungen geschrieben
7 Kommentare
Hello,
Can you point me to a place to purchase a replacement battery? Thanks,
Dan Goldman, daniel.goldman@physics.gatech.edu
Dan Goldman - Antwort
Would recommend the screw size be ad to the guide please.
John Walshaw - Antwort
Like Dan, I need to get a replacement battery. Any idea where it can be purchased (safely)?
Thanks :D
Michelle N - Antwort
not able to get beyond step 4. Any ideas how to open the small screws. I tried PH#000, and many others, but no luck
Steve Kumar - Antwort
the battery shown here is not the same for the Q325U, different battery connectors.
Joshua Delgado - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 14
Letzte 30 Tage: 39
Insgesamt: 4,463
