Einleitung
This guide will demonstrate how to replace the hard drive on the Asus Q500A.
Was du brauchst
Use a J0 screwdriver bit to remove both screws on the back-plate, found at the bottom of device.
Remove back-plate.
Note: Use prying tool if your having issues lifting back-plate.
Remove 4 screws from the metal hard-drive case. There will be one in each corner.
Remove the hard-drive case from the device.
Remove the hard-drive. It will be connected to the integrated sata-port in the device.
Place hard-drive into slot and connect to the integrated sata port.
Place hard drive case back on top of the new hard-drive.
Screw in the four screws on the hard-drive case.
Place back-plate back on device.
Screw in the 2 screws on the back of the plate.
2 weitere Personen haben diese Anleitung absolviert.
