Zum Hauptinhalt wechseln
Asus Q500A RAM Replacement
Was du brauchst
  1. Asus Q500A RAM Replacement, RAM: Schritt 1, Bild 1 von 2 Asus Q500A RAM Replacement, RAM: Schritt 1, Bild 2 von 2
    • Flip device upside-down.
    • Remove back-plate by unscrewing the two screws on either side of the back-plate.
    • Remove the plastic cover.
  2. Asus Q500A RAM Replacement: Schritt 2, Bild 1 von 1
    • Depending on the model of the device, there will either be one or two sticks of ram.
    • There are two metal brackets holding each ram stick in.
    • To unlock the RAM, you'll need to remove the metal brackets. To do this, carefully push out the brackets.
  3. Asus Q500A RAM Replacement: Schritt 3, Bild 1 von 2 Asus Q500A RAM Replacement: Schritt 3, Bild 2 von 2
    • Now simply remove the ram by pulling it out using a set of pliers to be safe and careful not to damage the ram.
  4. Asus Q500A RAM Replacement: Schritt 4, Bild 1 von 1
    • To insert the ram line up the ram stick and the slot.
    • Next you will have to push the ram down until it snaps into place.
    • Be careful not to do this too hard, as it can break the ram.
    • Make sure the ram is secure in its slot before moving on to the next piece of ram or replacing the back-plate.
Abschluss
cameron
319 Reputation
3 Anleitungen geschrieben
USF Tampa, Team 12-5, Eyestone Spring 2017 Mitglied von USF Tampa, Team 12-5, Eyestone Spring 2017
USFT-EYESTONE-S17S12G5
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 775
