Zum Hauptinhalt wechseln
Asus Q501LA-BBI6T03 Hard Drive Replacement
Was du brauchst
  1. Asus Q501LA-BBI6T03 Hard Drive Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Ensure the laptop is powered down before continuing.
    • Use a Phillips #0 screwdriver to remove the ten 3mm Phillips head screws on the base of the laptop.
  2. Asus Q501LA-BBI6T03 Hard Drive Replacement: Schritt 2, Bild 1 von 1
    • Use the spudger to pry open the rear cover at either hinge.
  3. Asus Q501LA-BBI6T03 Hard Drive Replacement: Schritt 3, Bild 1 von 2 Asus Q501LA-BBI6T03 Hard Drive Replacement: Schritt 3, Bild 2 von 2
    • Grab the cover with your fingers and gently lift it away from the board.
    • Be careful not to break any tabs on the cover when lifting it off.
  4. Asus Q501LA-BBI6T03 Hard Drive Replacement, Hard Drive: Schritt 4, Bild 1 von 1
    • Remove the four 3mm Phillips #0 screws shown.
  5. Asus Q501LA-BBI6T03 Hard Drive Replacement: Schritt 5, Bild 1 von 1
    • Take hard drive out of the port by sliding the component to the left.
    • There is only one way it comes out of the connector. If it seems too hard to push out you are probably going the wrong way.
  6. Asus Q501LA-BBI6T03 Hard Drive Replacement: Schritt 6, Bild 1 von 1
    • Once the hard drive has been removed from the connector, use your thumb to get under and lift the hard drive out.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Aodhan Arias
288 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 8-1, Banghart Winter 2017 Mitglied von Cal Poly, Team 8-1, Banghart Winter 2017
CPSU-BANGHART-W17S8G1
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 6
Insgesamt: 2,654
