Zum Hauptinhalt wechseln
Asus Q501LA-BBI6T03 Heat Sink Disassembly
Was du brauchst
  1. Asus Q501LA-BBI6T03 Heat Sink Disassembly, Back Panel: Schritt 1, Bild 1 von 1
    • Ensure the laptop is powered down before continuing.
    • Use a Phillips #0 screwdriver to remove the ten 3mm Phillips head screws on the base of the laptop.
  2. Asus Q501LA-BBI6T03 Heat Sink Disassembly: Schritt 2, Bild 1 von 1
    • Use the spudger to pry open the rear cover at either hinge.
  3. Asus Q501LA-BBI6T03 Heat Sink Disassembly: Schritt 3, Bild 1 von 2 Asus Q501LA-BBI6T03 Heat Sink Disassembly: Schritt 3, Bild 2 von 2
    • Grab the cover with your fingers and gently lift it away from the board.
    • Be careful not to break any tabs on the cover when lifting it off.
  4. Asus Q501LA-BBI6T03 Heat Sink Disassembly, Heat Sink/Fan Assembly: Schritt 4, Bild 1 von 1
    • Remove the seven 4mm Phillips #0 screws holding the heat sink/fan assembly onto the motherboard.
  5. Asus Q501LA-BBI6T03 Heat Sink Disassembly: Schritt 5, Bild 1 von 1
    • Using the spudger, unplug the fan from the motherboard connection by carefully pushing on both sides of the connector.
  6. Asus Q501LA-BBI6T03 Heat Sink Disassembly: Schritt 6, Bild 1 von 1
    • Lift up on the fan, copper heat pipe and heat sink assembly, and remove from motherboard.
    • Be careful when removing the heat sink unit from the CPU, as there will be thermal paste residue that will have be to cleaned and new thermal paste applied.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Kyle Nagao
366 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 8-1, Banghart Winter 2017 Mitglied von Cal Poly, Team 8-1, Banghart Winter 2017
CPSU-BANGHART-W17S8G1
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 13
Insgesamt: 776
