Einleitung
The fan is responsible for cooling your laptop and ensuring that it doesn't overheat. Use this guide to replace a broken fan.
Was du brauchst
Flip the laptop over and remove the ten 11 mm Phillips #1 screws securing the back panel.
Carefully insert a plastic opening tool under one corner of the back panel.
Slide the tool along the seam to gently pry the panel up and away from the device.
Remove the eight 5 mm Phillips #1 screws securing the fan and copper piece to the motherboard.
Remove the wires by gently pulling them out.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
