Zum Hauptinhalt wechseln
Asus Q502LA-BSI5T14 Keyboard Replacement
Was du brauchst
  1. Asus Q502LA-BSI5T14 Keyboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Ensure your device is powered off before starting.
    • Flip the laptop over and remove the ten 10 mm Phillips #1 screws securing the back panel.
  2. Asus Q502LA-BSI5T14 Keyboard Replacement: Schritt 2, Bild 1 von 1
    • Carefully insert a plastic opening tool under one corner of the back panel.
    • Slide the tool along the seam to gently pry the panel up and away from the device.
  3. Asus Q502LA-BSI5T14 Keyboard Replacement: Schritt 3, Bild 1 von 2 Asus Q502LA-BSI5T14 Keyboard Replacement: Schritt 3, Bild 2 von 2
    • The battery is the large L-shaped block.
    • Remove the five 5.5 mm Phillips #1 screws securing it.
  4. Asus Q502LA-BSI5T14 Keyboard Replacement: Schritt 4, Bild 1 von 2 Asus Q502LA-BSI5T14 Keyboard Replacement: Schritt 4, Bild 2 von 2
    • Using a plastic opening tool, lift the battery straight upward to remove it.
    • There are a series of eight small wires connecting the battery to the motherboard. Make sure you gently lift the battery straight up to disconnect these wires and prevent damage.
  5. Asus Q502LA-BSI5T14 Keyboard Replacement, Motherboard: Schritt 5, Bild 1 von 2 Asus Q502LA-BSI5T14 Keyboard Replacement, Motherboard: Schritt 5, Bild 2 von 2
    • Remove the four ribbons connected to the motherboard.
  6. Asus Q502LA-BSI5T14 Keyboard Replacement: Schritt 6, Bild 1 von 2 Asus Q502LA-BSI5T14 Keyboard Replacement: Schritt 6, Bild 2 von 2
    • Disconnect the five wires attached to the motherboard by pulling gently. There are three thin wires in the upper left corner.
  7. Asus Q502LA-BSI5T14 Keyboard Replacement: Schritt 7, Bild 1 von 1
    • Remove the two 5 mm Phillips #1 screws attaching the stabilizer to the motherboard
  8. Asus Q502LA-BSI5T14 Keyboard Replacement: Schritt 8, Bild 1 von 1
    • Remove the four 5 mm Phillips #1 screws around the perimeter of the motherboard.
  9. Asus Q502LA-BSI5T14 Keyboard Replacement: Schritt 9, Bild 1 von 2 Asus Q502LA-BSI5T14 Keyboard Replacement: Schritt 9, Bild 2 von 2
    • Remove the six 5 mm Phillips #1 screws securing the silver plates to the motherboard.
    • Open the laptop approximately 1/2" to loosen the hinge and release the motherboard.
  10. Asus Q502LA-BSI5T14 Keyboard Replacement: Schritt 10, Bild 1 von 1
    • Gently lift the motherboard out and away from the laptop.
  11. Asus Q502LA-BSI5T14 Keyboard Replacement, Keyboard: Schritt 11, Bild 1 von 2 Asus Q502LA-BSI5T14 Keyboard Replacement, Keyboard: Schritt 11, Bild 2 von 2
    • Remove the one 5 mm Phillips #1 screw.
    • Pull out the green plastic in order to free the keyboard underneath.
    • It is not necessary to unattach the green plastic completely .
  12. Asus Q502LA-BSI5T14 Keyboard Replacement: Schritt 12, Bild 1 von 2 Asus Q502LA-BSI5T14 Keyboard Replacement: Schritt 12, Bild 2 von 2
    • Start peeling the black cover from the bottom left corner gently.
    • Continue until the black cover is fully removed.
  13. Asus Q502LA-BSI5T14 Keyboard Replacement: Schritt 13, Bild 1 von 2 Asus Q502LA-BSI5T14 Keyboard Replacement: Schritt 13, Bild 2 von 2
    • Insert black Spudger in bottom left corner and lift the keyboard up.
    • Slide the black Spudger underneath the keyboard to loosen it.
    • Little black pieces that hold the keyboard in place will pop out while you lift the keyboard up.
    • This part is difficult and requires a gentle but forceful movement.
  14. Asus Q502LA-BSI5T14 Keyboard Replacement: Schritt 14, Bild 1 von 1
    • Lift up the keyboard once it is loosened to remove it.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Mary Kounelas
715 Reputation
5 Anleitungen geschrieben
USF Tampa, Team S4-G1, Eyestone Fall 2017 Mitglied von USF Tampa, Team S4-G1, Eyestone Fall 2017
USFT-EYESTONE-F17S4G1
4 Mitglieder
Ein Kommentar
Step 4 was misleading. It should have unplugged the cable before lifting the battery. I broke my battery connector off the mobo by following these directions. Lift straight up? That’s silly given how short the battery connection cable is.
Stevo Dumpert - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 9
Insgesamt: 944
