Einleitung
If you're having trouble with the Motherboard of your Asus laptop (model Q504UA-BHI5T13) this is the guide for you. The motherboard is used for distributing power throughout the computer, maintaining the memory and connecting to other CPU's. A faulty motherboard could cause problems to any of these computer functions. Before disassembling the computer ensure that you have the correct replacement motherboard (this can be found by consulting the laptop’s user manual or contacting the manufacturer directly). When finished with the replacement instructions take the previous motherboard to an e-recycling facility for the safest disposal method.
Be sure that there is no external power cord connected and that the laptop is fully powered off and shut down.
Was du brauchst
Use the T5 Torx screwdriver to remove the ten 1mm screws located around the back cover.
Use the Phillips #0 screwdriver to remove the two 4mm screws that are under the rubber pads.
Insert any of the plastic opening tools into the seam to separate the back cover (it is recommended to start at the corner of the hinges). If you did it right, then the cover should pop off.
Once the back cover is removed, have the laptop facing upside down with the hinges facing toward you.
Use the Phillips #0 screwdriver to remove the five 4mm screws around the battery.
Use the small plastic opening tool to remove the ZIF Connector on the right side of the battery.
Once the back cover is removed, have the laptop facing upside down with the hinges facing nearest to you.
Using a Phillips #0 screwdriver, remove the three black 4mm screws located around the heat sink fan.
Using the same screwdriver, remove the four 4mm black screws around the copper lining
First remove the screw in the red circle.
Then remove the screw in the orange circle.
Next remove the screw in the yellow circle.
Finally, remove the screw in the green circle.
Carefully unravel the cables (two black and one white) to the left of the heat sink fan.
Use the Phillips #0 screwdriver to remove the eight 4mm screws around the hard drive casing (located next to the Right [R] speaker).
Start off with the four black outer screws so that the casing can be released from the laptop unit.
The next sequence of screws to remove are the four silver screws.
Use the Phillips #0 screwdriver to remove the remaining eight 4.0 mm screws.
Ein Kommentar
Is there a replaceable ram stick on the other side of the motherboard? It looks like there is only one slot on the top side.
