Zum Hauptinhalt wechseln
Asus Q504UA-BHI5T13 Touch-pad Replacement
Was du brauchst
  1. Asus Q504UA-BHI5T13 Touch-pad Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Ensure that the laptop is off so you do not shock yourself.
  2. Asus Q504UA-BHI5T13 Touch-pad Replacement: Schritt 2, Bild 1 von 1
    • Use the T5 Torx screwdriver to remove the ten 1mm screws located around the back cover.
  3. Asus Q504UA-BHI5T13 Touch-pad Replacement: Schritt 3, Bild 1 von 1
    • Remove the two rubber pads nearest to you using the metal spudger.
  4. Asus Q504UA-BHI5T13 Touch-pad Replacement: Schritt 4, Bild 1 von 1
    • Use the Phillips #0 screwdriver to remove the two 4mm screws that are under the rubber pads.
  5. Asus Q504UA-BHI5T13 Touch-pad Replacement: Schritt 5, Bild 1 von 1
    • Insert any of the plastic opening tools into the seam to separate the back cover (it is recommended to start at the corner of the hinges). If you did it right, then the cover should pop off.
    • Be careful as you may damage the tabs.
  6. Asus Q504UA-BHI5T13 Touch-pad Replacement, Battery: Schritt 6, Bild 1 von 1
    • Once the back cover is removed, have the laptop facing upside down with the hinges facing toward you.
  7. Asus Q504UA-BHI5T13 Touch-pad Replacement: Schritt 7, Bild 1 von 1
    • Use the Phillips #0 screwdriver to remove the five 4mm screws around the battery.
  8. Asus Q504UA-BHI5T13 Touch-pad Replacement: Schritt 8, Bild 1 von 2 Asus Q504UA-BHI5T13 Touch-pad Replacement: Schritt 8, Bild 2 von 2
    • Use the small plastic opening tool to remove the ZIF Connector on the right side of the battery.
  9. Asus Q504UA-BHI5T13 Touch-pad Replacement: Schritt 9, Bild 1 von 2 Asus Q504UA-BHI5T13 Touch-pad Replacement: Schritt 9, Bild 2 von 2
    • Remove the battery from the device.
  10. Asus Q504UA-BHI5T13 Touch-pad Replacement, Touch-pad: Schritt 10, Bild 1 von 1
    • Pull the large data ribbon near the touch-pad out of the way with your hands.
    • Use the Phillips #0 screwdriver to remove the three 3.0 mm screws connecting the touch-pad to the device.
  11. Asus Q504UA-BHI5T13 Touch-pad Replacement: Schritt 11, Bild 1 von 2 Asus Q504UA-BHI5T13 Touch-pad Replacement: Schritt 11, Bild 2 von 2
    • Use the small plastic opening tool to remove the ZIF Connector on the left side of the touch-pad.
  12. Asus Q504UA-BHI5T13 Touch-pad Replacement: Schritt 12, Bild 1 von 2 Asus Q504UA-BHI5T13 Touch-pad Replacement: Schritt 12, Bild 2 von 2
    • Pry the end closest to the display up with your fingers and pull the touch-pad out.
Abschluss
Jacob Fritsch
337 Reputation
3 Anleitungen geschrieben
IUPUI, Team S1-G2, Henning Fall 2019 Mitglied von IUPUI, Team S1-G2, Henning Fall 2019
IUPUI-HENNING-F19S1G2
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 10
Insgesamt: 269
