Einleitung
Is your Asus Q525U laptop unable to hold a charge or power up without being connected to a charging cord? Follow this guide if you need to replace the battery of your Asus Q525U.
Before beginning this guide, be sure to turn off your laptop and disconnect from the power adapter.
Was du brauchst
Carefully remove the two longer 9.5 mm screws on the corners with a Phillips #1 screwdriver.
Remove the eight 7.5 mm Phillips #1 screws on the back of the device.
Once the cover has been separated from the device, carefully lift the back cover off the device (begin by lifting from the front of the cover first).
The battery of the device is outlined in red.
Using a Phillips #1 screwdriver, remove the four 5 mm screws that are holding the battery in place.
In diesem Schritt verwendetes Werkzeug:Halberd Spudger$2.99
Using the Halberd spudger, carefully lift the battery connector up to disconnect it from the motherboard.
