Zum Hauptinhalt wechseln
Asus Q534U CPU Fan/Heat Sink Replacement
Was du brauchst
  1. Asus Q534U CPU Fan/Heat Sink Replacement, Back Case Removal: Schritt 1, Bild 1 von 1
    • Make sure the device is turned off and unplugged from the charger.
    • Use a T5 screwdriver to remove all 10 screws that secure the bottom cover.
    • Pull off the back cover of the laptop.
    • A pry tool may be needed to pull off the back cover.
  2. Asus Q534U CPU Fan/Heat Sink Replacement: Schritt 2, Bild 1 von 2 Asus Q534U CPU Fan/Heat Sink Replacement: Schritt 2, Bild 2 von 2
    • Wedge an opening tool under the battery's bundled cable connector, and gently pry the connector up and to disconnect the battery.
  3. Asus Q534U CPU Fan/Heat Sink Replacement: Schritt 3, Bild 1 von 2 Asus Q534U CPU Fan/Heat Sink Replacement: Schritt 3, Bild 2 von 2
    • Lift up the black tab next to the silver ribbon cable.
    • Pull lightly on the blue tabs until the silver cable is free.
  4. Asus Q534U CPU Fan/Heat Sink Replacement: Schritt 4, Bild 1 von 1
    • Use a Phillips #00 screwdriver to remove the 5 marked screws.
    • Gently remove the battery.
    • Do not bend or puncture the laptop's lithium-polymer pattery.
  5. Asus Q534U CPU Fan/Heat Sink Replacement, CPU Fan/Heat Sink: Schritt 5, Bild 1 von 2 Asus Q534U CPU Fan/Heat Sink Replacement, CPU Fan/Heat Sink: Schritt 5, Bild 2 von 2
    • Using the iFixit opening tool, gently pry the CPU fan connector out of the socket.
  6. Asus Q534U CPU Fan/Heat Sink Replacement: Schritt 6, Bild 1 von 2 Asus Q534U CPU Fan/Heat Sink Replacement: Schritt 6, Bild 2 von 2
    • Move the black cable located around the CPU fan out of the holder.
    • Remove the following 9 screws:
    • Three Phillips screws
    • Six Phillips screws
    • Make sure not to mix up both types of screws.
    • Gently pull vertically on the CPU fan/ heat sink assembly until it is free.
    • Before placing a new CPU fan/heat sink assembly, the CPU and GPU surfaces must be cleaned off and thermal compound must be reapplied.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
mmedina
749 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team S66-G6, Rockett Fall 2017 Mitglied von UMass Dartmouth, Team S66-G6, Rockett Fall 2017
UMASSD-ROCKETT-F17S66G6
3 Mitglieder
5 Anleitungen geschrieben
Ein Kommentar
Is it possible to replace the fan only without removing the full heatsink or is it fused together as one unit?
Bork Bois - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 15
Insgesamt: 2,880
