Einleitung
If your battery does not hold a charge or is having issues with battery life, it may need to be replaced. In this guide, we will show you how to replace the battery.
Was du brauchst
Use a T4 Torx screwdriver head to remove the ten 4mm Torx head screws on the bottom of the laptop.
Use an opening tool to pry open the rear cover. Lift the cover off and away from the board.
Use a Phillips #0 screwdriver head to remove the three black 7mm Phillips head screws that hold the battery in place.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
