Zum Hauptinhalt wechseln
Asus Q550LF-BBI7T07 Disc Drive Replacement
Was du brauchst
  1. Asus Q550LF-BBI7T07 Disc Drive Replacement, Battery: Schritt 1, Bild 1 von 2 Asus Q550LF-BBI7T07 Disc Drive Replacement, Battery: Schritt 1, Bild 2 von 2
    • Use a T4 Torx screwdriver head to remove the ten 4mm Torx head screws on the bottom of the laptop.
  2. Asus Q550LF-BBI7T07 Disc Drive Replacement: Schritt 2, Bild 1 von 2 Asus Q550LF-BBI7T07 Disc Drive Replacement: Schritt 2, Bild 2 von 2
    • Use an opening tool to pry open the rear cover. Lift the cover off and away from the board.
  3. Asus Q550LF-BBI7T07 Disc Drive Replacement: Schritt 3, Bild 1 von 2 Asus Q550LF-BBI7T07 Disc Drive Replacement: Schritt 3, Bild 2 von 2
    • Use a Phillips #0 screwdriver head to remove the three black 7mm Phillips head screws that hold the battery in place.
  4. Asus Q550LF-BBI7T07 Disc Drive Replacement: Schritt 4, Bild 1 von 2 Asus Q550LF-BBI7T07 Disc Drive Replacement: Schritt 4, Bild 2 von 2
    • Once the screws have been removed, gently lift the battery out.
  5. Asus Q550LF-BBI7T07 Disc Drive Replacement, Hard Drive: Schritt 5, Bild 1 von 2 Asus Q550LF-BBI7T07 Disc Drive Replacement, Hard Drive: Schritt 5, Bild 2 von 2
    • Use the Phillips #0 Screwdriver to unscrew the four silver 5mm screws.
  6. Asus Q550LF-BBI7T07 Disc Drive Replacement: Schritt 6, Bild 1 von 2 Asus Q550LF-BBI7T07 Disc Drive Replacement: Schritt 6, Bild 2 von 2
    • Gently disconnect the Hard Drive from the connector cable. Lift it out and remove it.
  7. Asus Q550LF-BBI7T07 Disc Drive Replacement, Disc Drive: Schritt 7, Bild 1 von 2 Asus Q550LF-BBI7T07 Disc Drive Replacement, Disc Drive: Schritt 7, Bild 2 von 2
    • Use the Phillips #0 screwdriver to remove the two 7mm Phillips head screws from the metal disc drive holder.
  8. Asus Q550LF-BBI7T07 Disc Drive Replacement: Schritt 8, Bild 1 von 1
    • Lift the metal disc drive holder off of the disc drive to remove it.
  9. Asus Q550LF-BBI7T07 Disc Drive Replacement: Schritt 9, Bild 1 von 2 Asus Q550LF-BBI7T07 Disc Drive Replacement: Schritt 9, Bild 2 von 2
    • Use the Phillips #0 screwdriver to unscrew the one silver 5mm Phillips head screw that connects the disc drive to the motherboard.
  10. Asus Q550LF-BBI7T07 Disc Drive Replacement: Schritt 10, Bild 1 von 2 Asus Q550LF-BBI7T07 Disc Drive Replacement: Schritt 10, Bild 2 von 2
    • Slowly slide out the disc drive, keeping it level, to remove it.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 6
Insgesamt: 409
