Zum Hauptinhalt wechseln
Asus Q551L Repair Optical Drive Replacement
Was du brauchst
  1. Asus Q551L Repair Optical Drive Replacement, Back Panel: Schritt 1, Bild 1 von 2 Asus Q551L Repair Optical Drive Replacement, Back Panel: Schritt 1, Bild 2 von 2
    • Unscrew the 10 screws around the edge of the back panel. Eight of the screws are 0.0793mm T5 , two of them are 0.0793 JIS #0.
  2. Asus Q551L Repair Optical Drive Replacement: Schritt 2, Bild 1 von 1
    • Use the plastic opening tool to pry the back panel off the base of the laptop.
  3. Asus Q551L Repair Optical Drive Replacement, Optical Drive (PN UJ8E2): Schritt 3, Bild 1 von 3 Asus Q551L Repair Optical Drive Replacement, Optical Drive (PN UJ8E2): Schritt 3, Bild 2 von 3 Asus Q551L Repair Optical Drive Replacement, Optical Drive (PN UJ8E2): Schritt 3, Bild 3 von 3
    • Lift up the sticker that sticks between the motherboard and the optical drive. Then, unscrew the one screw where it is marked and slide it out gently.
    • Watch out for the wires around the optical drive.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 8
Insgesamt: 684
