Zum Hauptinhalt wechseln
Asus Q552UB-BHI7T12 Battery Replacement
Was du brauchst
  1. Asus Q552UB-BHI7T12 Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Remove all ten screws on the back of the laptop to remove the cover.
    • Remove the cover.
  2. Asus Q552UB-BHI7T12 Battery Replacement: Schritt 2, Bild 1 von 2 Asus Q552UB-BHI7T12 Battery Replacement: Schritt 2, Bild 2 von 2
    • Disconnect the wires at the top of the battery by lifting on the tabs protruding out of the plastic frame.
  3. Asus Q552UB-BHI7T12 Battery Replacement: Schritt 3, Bild 1 von 1
    • Remove the four screws holding the battery in place, two on top and one on each side.
  4. Asus Q552UB-BHI7T12 Battery Replacement: Schritt 4, Bild 1 von 1
    • Gently lift out the battery by the side closest to the motherboard first.
    • Be careful of any extra wires that may have attached itself to the battery.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Ein Kommentar
Greetings I have tried to pull the battery out but i have issues making it go out of the place where it clicks, could you make a detailed video on how to safely remove that part without breaking the wires or the soldering on the board???
jorgealanhurtado95 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 9
Insgesamt: 3,383
