Einleitung
RAM (Random Access Memory) is also known as system memory. Generally, 12 GB (8 GB and 4 GB) RAM is given by default with the Asus Q552UB-BHI7T12 Laptop. But users can upgrade up to 16 GB using two 8 GB RAMs. Normally the user needs to change the RAM when its performance degrades therefore the system becomes slower. But before changing the RAM, an Asus Q552UB-BHI7T12 user needs to confirm here that it’s actually the RAM which is causing the problem, not the CPU or Graphics Card.
Use this simple guide to replace your Asus Q552UB-BHI7T12 RAM. Follow these three simple steps which will take no longer than 10 minutes.
On the bottom of the laptop, gently pull the wire connecting the battery to the motherboard
Gently lever the two arms securing the RAM toward either side of the laptop, while holding the RAM in place with your thumbs.
Carefully slide the ram with your index fingers from in between the white tabs.
To reassemble device, follow the instructions in reverse order.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
