Einleitung
If your device is not powering on, the fault lies with the battery the majority of the time. Even if your PC is running correctly, the battery may be aged and isn't holding a charge as well as it could be. Replacing and removing the battery can be done by hand and very quickly.
  1. Locate the locking mechanisms that keep the battery in place and slide them outwards.
    • Locate the locking mechanisms that keep the battery in place and slide them outwards.
    • The right mechanism will lock in place, the left one you will need to hold in place.
  2. Use your right thumb to slide the right side of the battery out, then the left side.
    • Use your right thumb to slide the right side of the battery out, then the left side.
Abschluss
Matthew Diaz
Mitglied seit 15.02.2018
315 Reputation
2 Anleitungen geschrieben
USF Tampa, Team S1-G6, Leahy Spring 2018 Mitglied von USF Tampa, Team S1-G6, Leahy Spring 2018
USFT-LEAHY-S18S1G6
4 Mitglieder
5 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 82
