Zum Hauptinhalt wechseln
Asus R541UA-RB51 CD Drive Replacement
Was du brauchst
  1. Asus R541UA-RB51 CD Drive Replacement, Keyboard: Schritt 1, Bild 1 von 3 Asus R541UA-RB51 CD Drive Replacement, Keyboard: Schritt 1, Bild 2 von 3 Asus R541UA-RB51 CD Drive Replacement, Keyboard: Schritt 1, Bild 3 von 3
    • Flip the laptop over so that the back panel is facing up.
    • Carefully remove the eight 5.7mm screws on the back panel using a Phillips #1 screwdriver.
  2. Asus R541UA-RB51 CD Drive Replacement: Schritt 2, Bild 1 von 2 Asus R541UA-RB51 CD Drive Replacement: Schritt 2, Bild 2 von 2
    • Turn the laptop upright and flip the screen open.
    • Using the plastic opening tool, gently pry the keyboard panel off of the base.
  3. Asus R541UA-RB51 CD Drive Replacement: Schritt 3, Bild 1 von 2 Asus R541UA-RB51 CD Drive Replacement: Schritt 3, Bild 2 von 2
    • Gently raise the keyboard from the base enough to access the underside.
    • Gently pull up on the locking tab to release the ribbon cable. This should take no force to complete.
    • Remove the keyboard.
  4. Asus R541UA-RB51 CD Drive Replacement, CD Drive: Schritt 4, Bild 1 von 1
    • Remove the three 5.7 mm screws from the CD drive mounting points. Use a Phillips #1 screwdriver to remove the screws.
  5. Asus R541UA-RB51 CD Drive Replacement: Schritt 5, Bild 1 von 2 Asus R541UA-RB51 CD Drive Replacement: Schritt 5, Bild 2 von 2
    • Gently slide the CD drive away and pull up to remove it from the computer.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 13
Insgesamt: 321
