Einleitung
This guide will demonstrate how to remove and replace the hard drive on your Asus ROG G53SW-XT1.
Was du brauchst
Insert a spudger, or plastic opening tool, into these five slots and pry upwards to pop up the keyboard.
Insert your screwdriver into the locking mechanism and slide it to the left. This will unlock the hand rest and allow you to pull it free.
Place your fingers along the left edge of the hard drive cover, and slide it to the right, then lift up.
Remove the Hard Drive and case from the laptop.
Remove the four Phillips #0 screws from the hard drive case.
2 weitere Personen haben diese Anleitung absolviert.
1 Kommentar zur Anleitung
Bottom cover holds only by 9 screws. You don’t need to remove 14 screws. All screws at the bottom with M2 5x7 label (do not remove two small screws. And one scre on the right in the middle without number on the metal plate). You don’t need to remove screw with M2 5x7 label on the right side, second from the corner.
