Zum Hauptinhalt wechseln
Asus ROG G56JK Fan Replacement
Was du brauchst
  1. Asus ROG G56JK Fan Replacement, Battery: Schritt 1, Bild 1 von 2 Asus ROG G56JK Fan Replacement, Battery: Schritt 1, Bild 2 von 2
    • Push the slider to the opposite side, while pulling out the battery.
    • Remove the battery from the device.
  2. Asus ROG G56JK Fan Replacement, Hard Drive: Schritt 2, Bild 1 von 1
    • Remove the 4 mm screw on the cover using a Phillips #0 screwdriver.
    • Remove the cover for the hard drive by pushing down and sliding it towards yourself.
  3. Asus ROG G56JK Fan Replacement: Schritt 3, Bild 1 von 1
    • Slide the hard drive to left and remove it from the device.
  4. Asus ROG G56JK Fan Replacement, Back Panel: Schritt 4, Bild 1 von 1
    • Unscrew the four 4mm screws using a Phillips #0 screwdriver.
  5. Asus ROG G56JK Fan Replacement: Schritt 5, Bild 1 von 1
    • Flip the computer right side up and start to lift the keyboard. The keyboard/back panel should come off.
    • Do not force the keyboard/back panel off. This could damage internal components and bend the keyboard.
  6. Asus ROG G56JK Fan Replacement, Fan: Schritt 6, Bild 1 von 2 Asus ROG G56JK Fan Replacement, Fan: Schritt 6, Bild 2 von 2
    • Unplug the red and yellow wires from the port in the motherboard.
    • Lightly pull on the red and yellow wires to release.
  7. Asus ROG G56JK Fan Replacement: Schritt 7, Bild 1 von 1
    • Remove the 5mm screw.
    • Remove the 4mm screw.
  8. Asus ROG G56JK Fan Replacement: Schritt 8, Bild 1 von 1
    • The fan is glued to the black box that it is inside of. When pulling the fan out, you may experience a small amount of tearing of the black box.
    • Gently pull the fan out of the black box.
Abschluss
Jonathan McNary
269 Reputation
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 6
Letzte 30 Tage: 10
Insgesamt: 1,905
