Zum Hauptinhalt wechseln
Asus ROG G74SX-DH73-3D Battery Replacement
Was du brauchst
  1. Asus ROG G74SX-DH73-3D Battery Replacement, Battery: Schritt 1, Bild 1 von 3 Asus ROG G74SX-DH73-3D Battery Replacement, Battery: Schritt 1, Bild 2 von 3 Asus ROG G74SX-DH73-3D Battery Replacement, Battery: Schritt 1, Bild 3 von 3
    • With your right hand, push the latch completely up to where you can see the battery pop slightly up. Pick and pull at the tab with your left hand.
    • You can now fully remove the battery from the device.
Abschluss
Jackson Reynolds
346 Reputation
3 Anleitungen geschrieben
2 Kommentare
The note bullet should just be a bullet. Check grammar on the Red bullet.
Joseph McCoy - Antwort
“With your right hand, push the latch completely up to where you can see the battery pop slightly up. Pick and pull at the tab with your left hand.” The sentence is too wordy you can remove “Where you can see the battery pop slightly up”.
Nicholas Ivey - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 10
Insgesamt: 354
