Zum Hauptinhalt wechseln
Asus ROG G74SX-DH73-3D Disc/Optical Drive Replacement
Was du brauchst
  1. Asus ROG G74SX-DH73-3D Disc/Optical Drive Replacement, Disc/Optical Drive: Schritt 1, Bild 1 von 2 Asus ROG G74SX-DH73-3D Disc/Optical Drive Replacement, Disc/Optical Drive: Schritt 1, Bild 2 von 2
    • Place the device upside-down. Unscrew the screw at the top of the cover and remove the cover by using a plastic opening tool.
  2. Asus ROG G74SX-DH73-3D Disc/Optical Drive Replacement: Schritt 2, Bild 1 von 1
    • Remove the screw that is located on the right edge of the removed cover. The screw is in a small opening.
  3. Asus ROG G74SX-DH73-3D Disc/Optical Drive Replacement: Schritt 3, Bild 1 von 2 Asus ROG G74SX-DH73-3D Disc/Optical Drive Replacement: Schritt 3, Bild 2 von 2
    • Inside the opening that the screw was in, use a nylon spudger or any thin tool to push against the inside edge of the disc/optical drive.
    • With the disc/optical drive slightly popped out of the socket, pull the rest of it out by hand.
Abschluss
Jackson Reynolds
352 Reputation
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 9
Letzte 30 Tage: 27
Insgesamt: 308
