Zum Hauptinhalt wechseln
Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement
Was du brauchst
  1. Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement, Battery: Schritt 1, Bild 1 von 3 Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement, Battery: Schritt 1, Bild 2 von 3 Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement, Battery: Schritt 1, Bild 3 von 3
    • With your right hand, push the latch completely up to where you can see the battery pop slightly up. Pick and pull at the tab with your left hand.
    • You can now fully remove the battery from the device.
  2. Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement, Track Pad Buttons: Schritt 2, Bild 1 von 2 Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement, Track Pad Buttons: Schritt 2, Bild 2 von 2
    • Remove the large flathead screw holding the back cover in place.
    • Pull the cover off by prying it open starting from the top center and moving outwards.
  3. Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement: Schritt 3, Bild 1 von 2 Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement: Schritt 3, Bild 2 von 2
    • Remove the eight short screws holding in the two metal covers near the bottom.
    • Remove the two metal covers.
  4. Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement: Schritt 4, Bild 1 von 2 Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement: Schritt 4, Bild 2 von 2
    • Remove the battery to access the screws under it.
    • Remove these 16 screws with a regular Phillips head screw-driver.
    • These Phillips head screws will require a longer bit or an extension.
  5. Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement: Schritt 5, Bild 1 von 2 Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement: Schritt 5, Bild 2 von 2
    • Flip the device back over.
    • Pull off the plastic cover behind the screen.
    • Remove the four Phillips head screws holding the screen in place.
  6. Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement: Schritt 6, Bild 1 von 2 Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement: Schritt 6, Bild 2 von 2
    • With the screen removed, pry the piece that has the keyboard and the track pad on it.
  7. Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement: Schritt 7, Bild 1 von 2 Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement: Schritt 7, Bild 2 von 2
    • Remove the two Phillips head screws holding the buttons in place.
Abschluss
Josh Reyes
183 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 14
Insgesamt: 415
