Zum Hauptinhalt wechseln
Asus ROG G750JH-DB71 Fan Replacement
Was du brauchst
  1. Asus ROG G750JH-DB71 Fan Replacement, Battery: Schritt 1, Bild 1 von 2 Asus ROG G750JH-DB71 Fan Replacement, Battery: Schritt 1, Bild 2 von 2
    • Ensure the laptop is powered off and unplugged before beginning.
    • Flip the laptop over so the bottom case is facing up.
    Frag FixBot
    Kommentar hinzufügen
  2. Asus ROG G750JH-DB71 Fan Replacement: Schritt 2, Bild 1 von 3 Asus ROG G750JH-DB71 Fan Replacement: Schritt 2, Bild 2 von 3 Asus ROG G750JH-DB71 Fan Replacement: Schritt 2, Bild 3 von 3
    • Push the switch near the front of the laptop to release the battery from the computer.
    • Pull the battery out and away from the center of the computer.
    Frag FixBot
  3. Asus ROG G750JH-DB71 Fan Replacement, Asus ROG G750JH-DB71: Schritt 3, Bild 1 von 3 Asus ROG G750JH-DB71 Fan Replacement, Asus ROG G750JH-DB71: Schritt 3, Bild 2 von 3 Asus ROG G750JH-DB71 Fan Replacement, Asus ROG G750JH-DB71: Schritt 3, Bild 3 von 3
    • Use a spudger or your finger to lift up the plastic cover on the bottom of the laptop.
    • Under the plastic cover is a captive screw; unscrew it using a Phillips #00 screwdriver.
    Frag FixBot
  4. Asus ROG G750JH-DB71 Fan Replacement: Schritt 4, Bild 1 von 2 Asus ROG G750JH-DB71 Fan Replacement: Schritt 4, Bild 2 von 2
    • Remove the cover.
    • If your goal is to replace/remove only the hard drive, you don't have to complete the following disassembly steps and can go on to the hard drive replacement guide.
    Frag FixBot
  5. Asus ROG G750JH-DB71 Fan Replacement: Schritt 5, Bild 1 von 3 Asus ROG G750JH-DB71 Fan Replacement: Schritt 5, Bild 2 von 3 Asus ROG G750JH-DB71 Fan Replacement: Schritt 5, Bild 3 von 3
    • Remove the hard drive by unscrewing the 4.4 mm Phillips #00 screws.
    • Remove all of the plastic caps around the edges using a spudger. Remove the screws underneath the caps.
    • There is one 13 mm Phillips #00 screw and six 8 mm Phillips #00 screws.
    • Remove the remaining screws underneath the cover.
    • There are six 8 mm Phillips #00 screws and three 1 mm Phillips #00 screws.
    Frag FixBot
  6. Asus ROG G750JH-DB71 Fan Replacement: Schritt 6, Bild 1 von 3 Asus ROG G750JH-DB71 Fan Replacement: Schritt 6, Bild 2 von 3 Asus ROG G750JH-DB71 Fan Replacement: Schritt 6, Bild 3 von 3
    • You will find a metal tab holding the disc drive in place. Push on the tab with a spudger to remove the disc drive. It is located below a previously removed screw.
    • Do not pull the disc drive out from the side before pushing the metal tab as it will only damage the cover.
    • Remove the three 4 mm Phillips #00 screws that were previously covered by the disc drive.
    Frag FixBot
  7. Asus ROG G750JH-DB71 Fan Replacement: Schritt 7, Bild 1 von 3 Asus ROG G750JH-DB71 Fan Replacement: Schritt 7, Bild 2 von 3 Asus ROG G750JH-DB71 Fan Replacement: Schritt 7, Bild 3 von 3
    • The back cover can be taken off by hand.
    • Disconnect the speaker cables.
    • Remove two 8 mm Phillips #00 screws on each corner.
    Frag FixBot
  8. Asus ROG G750JH-DB71 Fan Replacement: Schritt 8, Bild 1 von 3 Asus ROG G750JH-DB71 Fan Replacement: Schritt 8, Bild 2 von 3 Asus ROG G750JH-DB71 Fan Replacement: Schritt 8, Bild 3 von 3
    • Pry the keyboard gently using a spudger.
    • Make sure to unhook the cables and wires from the keyboard gently in Picture 3.
    Frag FixBot
  9. Asus ROG G750JH-DB71 Fan Replacement: Schritt 9, Bild 1 von 2 Asus ROG G750JH-DB71 Fan Replacement: Schritt 9, Bild 2 von 2
    • Now you can pull the keyboard off but make sure to do so carefully without damaging or scuffing any components.
    • Pull up and out at an angle to avoid damaging the internals of the laptop.
    Frag FixBot
  10. Asus ROG G750JH-DB71 Fan Replacement, Fan: Schritt 10, Bild 1 von 1
    • Remove the Data and Wi-fi cables from the sockets shown.
    Frag FixBot
  11. Asus ROG G750JH-DB71 Fan Replacement: Schritt 11, Bild 1 von 3 Asus ROG G750JH-DB71 Fan Replacement: Schritt 11, Bild 2 von 3 Asus ROG G750JH-DB71 Fan Replacement: Schritt 11, Bild 3 von 3
    • Slowly close the lid and turn the device around.
    • Remove the 6 screws (3 on each side) from the edges of the device. (8mm Phillips 00)
    • Remove the Webcam cable.
    Frag FixBot
  12. Asus ROG G750JH-DB71 Fan Replacement: Schritt 12, Bild 1 von 3 Asus ROG G750JH-DB71 Fan Replacement: Schritt 12, Bild 2 von 3 Asus ROG G750JH-DB71 Fan Replacement: Schritt 12, Bild 3 von 3
    • Carefully lift the lid away from the rest of the device.
    • There may be tape covering the fans or other components. Remove it slowly as to not damage anything.
    Frag FixBot
  13. Asus ROG G750JH-DB71 Fan Replacement: Schritt 13, Bild 1 von 3 Asus ROG G750JH-DB71 Fan Replacement: Schritt 13, Bild 2 von 3 Asus ROG G750JH-DB71 Fan Replacement: Schritt 13, Bild 3 von 3
    • Remove the three screws surrounding each fan shown along with the ribbon cables connecting them to the motherboard. (4mm Phillips 00)
    • Remove the USB port board blocking the rightmost fan.
    • Remove the fans from the board.
    Frag FixBot
Abschluss
UMass Dartmouth, Team 5-5, Sinclaire Fall 2022 Mitglied von UMass Dartmouth, Team 5-5, Sinclaire Fall 2022
UMASSD-SINCLAIRE-F22S5G5
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 47
Insgesamt: 733
