Zum Hauptinhalt wechseln
Asus ROG G750JH-DB71 Hard Drive Replacement
Was du brauchst
  1. Asus ROG G750JH-DB71 Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 2 Asus ROG G750JH-DB71 Hard Drive Replacement, Battery: Schritt 1, Bild 2 von 2
    • Ensure the laptop is powered off and unplugged before beginning.
    • Flip the laptop over so the bottom case is facing up.
    Frag FixBot
    Kommentar hinzufügen
  2. Asus ROG G750JH-DB71 Hard Drive Replacement: Schritt 2, Bild 1 von 3 Asus ROG G750JH-DB71 Hard Drive Replacement: Schritt 2, Bild 2 von 3 Asus ROG G750JH-DB71 Hard Drive Replacement: Schritt 2, Bild 3 von 3
    • Push the switch near the front of the laptop to release the battery from the computer.
    • Pull the battery out and away from the center of the computer.
    Frag FixBot
  3. Asus ROG G750JH-DB71 Hard Drive Replacement, Hard Drive: Schritt 3, Bild 1 von 3 Asus ROG G750JH-DB71 Hard Drive Replacement, Hard Drive: Schritt 3, Bild 2 von 3 Asus ROG G750JH-DB71 Hard Drive Replacement, Hard Drive: Schritt 3, Bild 3 von 3
    • Use a pick or your finger to lift up the plastic cover on back of the laptop.
    • Under the plastic cover is a screw, unscrew it using a Phillips #00 screwdriver.
    • The screw has a c lock so it can not be unscrewed completely. Once Its loose pry on the seam using a screwdriver or the iFixit pry tool.
    Frag FixBot
  4. Asus ROG G750JH-DB71 Hard Drive Replacement: Schritt 4, Bild 1 von 3 Asus ROG G750JH-DB71 Hard Drive Replacement: Schritt 4, Bild 2 von 3 Asus ROG G750JH-DB71 Hard Drive Replacement: Schritt 4, Bild 3 von 3
    • Remove the cover.
    • Remove the four 4.0 mm Phillips #00 screws holding in the hard drive caddy.
    • Push the caddy towards the open space in its compartment to remove it.
    Frag FixBot
Abschluss
UMass Dartmouth, Team 5-5, Sinclaire Fall 2022 Mitglied von UMass Dartmouth, Team 5-5, Sinclaire Fall 2022
UMASSD-SINCLAIRE-F22S5G5
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 33
Insgesamt: 464
