Einleitung
This guide will show the user how to safely remove and replace the CD-ROM Player.
Was du brauchst
Lift the rubber cover found on the bottom of the laptop.
Remove the 5.2 mm screw with a Phillips 1 Screwdriver.
Use a Phillips 1 Screwdriver to remove the 5 mm screw that is located underneath the back panel.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
