Einleitung
This guide will teach you how to replace the Central Processing Unit in your device. This is important for the usability of the device.
Was du brauchst
Lift the rubber cover found on the bottom of the laptop.
Remove the 5.2 mm screw with a Phillips 1 Screwdriver
Use a Phillips 1 Screwdriver to remove the 5 mm screw that is located underneath the back panel.
Remove the screws holding the hard drives in place using a phillips #1 screwdriver.
Using the small flaps, remove the hard drives by hand.
Use a pair of tweezers to remove the top four rubber stoppers found on the bottom of the laptop.
Use a metal spudger to carefully pry the top back panel off.
Disconnect the four-pin connector and remove the top back panel from the computer.
Use a Phillips 1 Screwdriver to remove the four 6.8 mm screws underneath the back panel.
Use a Phillips 1 Screwdriver to remove the ten 5.2 mm screws holding the main panel in place.
Use a pair of tweezers to undo each of the four ribbon connectors.
The keyboard is now completely disconnected from the laptop and you can remove it.
The CPU can then be removed with a regular spudger.
The CPU is now completely disconnected from the laptop and you can remove it.
2 Kommentare
Hi Justin, if I were to remove the motherboard and insert a new one using your procedure would I have to change anything in the bios or will just a physical switch do the thing.
I was following this guide normally but then I saw the last step... are you f***ing kidding me?! You DO NOT PRY OFF that chip!! It's a BGA connection and you WILL destroy it. If you need your CPU or GPU replaced, either buy a new motherboard or seek a professional's service that replaces chips like that. But yikes, an iFixit guide that's pretty coherent yet the last step implies removing the chip and damaging it... I must be hallucinating. If anyone did mindlessly follow this guide without prior experience... you have my deepest condolences.
