Zum Hauptinhalt wechseln
Asus ROG G751JL-DS71 Monitor Replacement
Was du brauchst
  1. Asus ROG G751JL-DS71 Monitor Replacement, CD-ROM Player: Schritt 1, Bild 1 von 2 Asus ROG G751JL-DS71 Monitor Replacement, CD-ROM Player: Schritt 1, Bild 2 von 2
    • Lift the rubber cover found on the bottom of the laptop.
    • Remove the 5.2 mm screw with a Phillips 1 Screwdriver.
  2. Asus ROG G751JL-DS71 Monitor Replacement: Schritt 2, Bild 1 von 3 Asus ROG G751JL-DS71 Monitor Replacement: Schritt 2, Bild 2 von 3 Asus ROG G751JL-DS71 Monitor Replacement: Schritt 2, Bild 3 von 3
    • Use the nylon spudger to remove the back center panel.
  3. Asus ROG G751JL-DS71 Monitor Replacement: Schritt 3, Bild 1 von 2 Asus ROG G751JL-DS71 Monitor Replacement: Schritt 3, Bild 2 von 2
    • Use a Phillips 1 Screwdriver to remove the 5 mm screw that is located underneath the back panel.
  4. Asus ROG G751JL-DS71 Monitor Replacement: Schritt 4, Bild 1 von 2 Asus ROG G751JL-DS71 Monitor Replacement: Schritt 4, Bild 2 von 2
    • Pull out the optical drive found on the side of the laptop.
  5. Asus ROG G751JL-DS71 Monitor Replacement, Top Rear Panel: Schritt 5, Bild 1 von 2 Asus ROG G751JL-DS71 Monitor Replacement, Top Rear Panel: Schritt 5, Bild 2 von 2
    • Use a pair of tweezers to remove the top four rubber stoppers found on the bottom of the laptop.
  6. Asus ROG G751JL-DS71 Monitor Replacement: Schritt 6, Bild 1 von 2 Asus ROG G751JL-DS71 Monitor Replacement: Schritt 6, Bild 2 von 2
    • Use a Phillips 1 Screwdriver to remove the top four 8.5 mm screws.
  7. Asus ROG G751JL-DS71 Monitor Replacement: Schritt 7, Bild 1 von 3 Asus ROG G751JL-DS71 Monitor Replacement: Schritt 7, Bild 2 von 3 Asus ROG G751JL-DS71 Monitor Replacement: Schritt 7, Bild 3 von 3
    • Use a nylon spudger to carefully pry the top back panel off.
    • While removing the top back panel, be careful not to break the four pin connector located underneath.
    • Disconnect the four-pin connector and remove the top back panel from the computer.
  8. Asus ROG G751JL-DS71 Monitor Replacement, Keyboard: Schritt 8, Bild 1 von 3 Asus ROG G751JL-DS71 Monitor Replacement, Keyboard: Schritt 8, Bild 2 von 3 Asus ROG G751JL-DS71 Monitor Replacement, Keyboard: Schritt 8, Bild 3 von 3
    • Use a Phillips 1 Screwdriver to remove the four 6.8 mm screws underneath the back panel.
    • Lift away the metal housings from each side of the laptop.
  9. Asus ROG G751JL-DS71 Monitor Replacement: Schritt 9, Bild 1 von 2 Asus ROG G751JL-DS71 Monitor Replacement: Schritt 9, Bild 2 von 2
    • Use a Phillips 1 Screwdriver to remove the ten 5.2 mm screws holding the main panel in place.
    • Use a Phillips 1 Screwdriver to remove the four 5.2 mm screws underneath the center panel.
  10. Asus ROG G751JL-DS71 Monitor Replacement: Schritt 10, Bild 1 von 3 Asus ROG G751JL-DS71 Monitor Replacement: Schritt 10, Bild 2 von 3 Asus ROG G751JL-DS71 Monitor Replacement: Schritt 10, Bild 3 von 3
    • Use a plastic opening tool to pry the keyboard from the base of the laptop.
    • Lift the keyboard carefully so as to not tear or break the four ribbon connectors underneath the keyboard.
  11. Asus ROG G751JL-DS71 Monitor Replacement: Schritt 11, Bild 1 von 2 Asus ROG G751JL-DS71 Monitor Replacement: Schritt 11, Bild 2 von 2
    • Use a pair of tweezers to undo each of the four ribbon connectors.
    • The keyboard is now completely disconnected from the laptop and you can remove it.
  12. Asus ROG G751JL-DS71 Monitor Replacement, Monitor: Schritt 12, Bild 1 von 2 Asus ROG G751JL-DS71 Monitor Replacement, Monitor: Schritt 12, Bild 2 von 2
    • Use a pair of tweezers to carefully disconnect the pin connector.
  13. Asus ROG G751JL-DS71 Monitor Replacement: Schritt 13, Bild 1 von 3 Asus ROG G751JL-DS71 Monitor Replacement: Schritt 13, Bild 2 von 3 Asus ROG G751JL-DS71 Monitor Replacement: Schritt 13, Bild 3 von 3
    • Use a Phillips 1 Screwdriver to remove the final four remaining 6.8 mm screws located underneath the back panel.
    • The monitor is now free to be completely lifted off the laptop.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Cal Poly, Team S16-G1, Banghart Winter 2018 Mitglied von Cal Poly, Team S16-G1, Banghart Winter 2018
CPSU-BANGHART-W18S16G1
4 Mitglieder
22 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 4
Letzte 30 Tage: 11
Insgesamt: 714
