Zum Hauptinhalt wechseln
Einleitung
This guide will show the user how to safely remove and replace the Top Rear Panel.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Use a pair of tweezers to remove the top four rubber stoppers found on the bottom of the laptop. Use a pair of tweezers to remove the top four rubber stoppers found on the bottom of the laptop.
    • Use a pair of tweezers to remove the top four rubber stoppers found on the bottom of the laptop.
  2. iPhone X Fix Kits
    Warranty up? No worries, we’ve got the fix.
    Jetzt kaufen
    iPhone X Fix Kits
    Jetzt kaufen
  3. Use a Phillips 1 Screwdriver to remove the top four 8.5 mm screws. Use a Phillips 1 Screwdriver to remove the top four 8.5 mm screws.
    • Use a Phillips 1 Screwdriver to remove the top four 8.5 mm screws.
  4. Use a nylon spudger to carefully pry the top back panel off. While removing the top back panel, be careful not to break the four pin connector located underneath. Disconnect the four-pin connector and remove the top back panel from the computer.
    • Use a nylon spudger to carefully pry the top back panel off.
    • While removing the top back panel, be careful not to break the four pin connector located underneath.
    • Disconnect the four-pin connector and remove the top back panel from the computer.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Aurora Rios
712 Reputation
4 Anleitungen geschrieben
Cal Poly, Team S16-G1, Banghart Winter 2018 Mitglied von Cal Poly, Team S16-G1, Banghart Winter 2018
CPSU-BANGHART-W18S16G1
4 Mitglieder
7 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 73
