Zum Hauptinhalt wechseln
Asus ROG G751JT-DH72 RAM Replacement
Was du brauchst
  1. Asus ROG G751JT-DH72 RAM Replacement, RAM: Schritt 1, Bild 1 von 2 Asus ROG G751JT-DH72 RAM Replacement, RAM: Schritt 1, Bild 2 von 2
    • Lift up the rubber tab located in the upper-right corner of the backing plate.
  2. Asus ROG G751JT-DH72 RAM Replacement: Schritt 2, Bild 1 von 1
    • Use a Phillips #1 screwdriver to remove the 5.2 mm screw behind the rubber tap.
  3. Asus ROG G751JT-DH72 RAM Replacement: Schritt 3, Bild 1 von 1
    • Carefully pull the backing plate off. If you have a pry tool, you can pry on the edges carefully.
  4. Asus ROG G751JT-DH72 RAM Replacement: Schritt 4, Bild 1 von 1
    • Use a Phillips #1 screwdriver to remove the 5mm screw on the right side.
  5. Asus ROG G751JT-DH72 RAM Replacement: Schritt 5, Bild 1 von 1
    • Pull out the optical drive to revel the screws holding the laptop cover.
  6. Asus ROG G751JT-DH72 RAM Replacement: Schritt 6, Bild 1 von 2 Asus ROG G751JT-DH72 RAM Replacement: Schritt 6, Bild 2 von 2
    • Remove all 10 5.2mm Phillips screws holding the main back cover using the Phillips #1 screwdriver.
  7. Asus ROG G751JT-DH72 RAM Replacement: Schritt 7, Bild 1 von 1
    • Remove the four 5.2mm screws directly behind the backing plate using the Phillips #1 screwdriver.
  8. Asus ROG G751JT-DH72 RAM Replacement: Schritt 8, Bild 1 von 1
    • Flip over the laptop and pry the 2 vent covers off.
  9. Asus ROG G751JT-DH72 RAM Replacement: Schritt 9, Bild 1 von 1
    • Remove the two 6.8mm Phillips screws directly below the vent covers using the Phillips #1 screwdriver.
  10. Asus ROG G751JT-DH72 RAM Replacement: Schritt 10, Bild 1 von 2 Asus ROG G751JT-DH72 RAM Replacement: Schritt 10, Bild 2 von 2
    • Pry along the edges of the keyboard to lift it up.
    • Be careful not to damage the ribbon connectors.
  11. Asus ROG G751JT-DH72 RAM Replacement: Schritt 11, Bild 1 von 2 Asus ROG G751JT-DH72 RAM Replacement: Schritt 11, Bild 2 von 2
    • Disconnect all 4 ribbon connectors with a tweezer.
  12. Asus ROG G751JT-DH72 RAM Replacement: Schritt 12, Bild 1 von 1
    • Carefully, pull on the side tabs to release the RAM card.
Abschluss
Anum Haidari
558 Reputation
3 Anleitungen geschrieben
UC Davis, Team S7-G4, Lore Fall 2018 Mitglied von UC Davis, Team S7-G4, Lore Fall 2018
UCD-LORE-F18S7G4
2 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 24
Insgesamt: 1,119
