Einleitung
Use this guide to replace the RAM in your device.
Was du brauchst
Lift up the rubber tab located in the upper-right corner of the backing plate.
Use a Phillips #1 screwdriver to remove the 5.2 mm screw behind the rubber tap.
Carefully pull the backing plate off. If you have a pry tool, you can pry on the edges carefully.
Remove all 10 5.2mm Phillips screws holding the main back cover using the Phillips #1 screwdriver.
Remove the four 5.2mm screws directly behind the backing plate using the Phillips #1 screwdriver.
Remove the two 6.8mm Phillips screws directly below the vent covers using the Phillips #1 screwdriver.
