Zum Hauptinhalt wechseln
Asus ROG STRIX GL502V Motherboard Replacement
Was du brauchst
  1. Asus ROG STRIX GL502V Motherboard Replacement, Asus ROG STRIX GL502V Lower Case: Schritt 1, Bild 1 von 2 Asus ROG STRIX GL502V Motherboard Replacement, Asus ROG STRIX GL502V Lower Case: Schritt 1, Bild 2 von 2
    • Remove 10 screws.
    • Note: front screws (blue) are 10mm long, central and rear (brown) are 12mm.
  2. Asus ROG STRIX GL502V Motherboard Replacement: Schritt 2, Bild 1 von 2 Asus ROG STRIX GL502V Motherboard Replacement: Schritt 2, Bild 2 von 2
    • With opening tool or pick go around the case starting from back corner.
  3. Asus ROG STRIX GL502V Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Lift cover and now you have access to most of the components.
  4. Asus ROG STRIX GL502V Motherboard Replacement, Battery: Schritt 4, Bild 1 von 1
    • Disconnect battery connect by pulling it up.
  5. Asus ROG STRIX GL502V Motherboard Replacement: Schritt 5, Bild 1 von 1
    • Remove 4 screws
  6. Asus ROG STRIX GL502V Motherboard Replacement: Schritt 6, Bild 1 von 1
    • Lift battery up and out.
  7. Asus ROG STRIX GL502V Motherboard Replacement, Remove memory module: Schritt 7, Bild 1 von 1
    • Pull spring locks out.
    • Lift module up and out of the connector.
  8. Asus ROG STRIX GL502V Motherboard Replacement, M.2 SSD: Schritt 8, Bild 1 von 1
    • remove screw.
    • pull up and right from the connector.
  9. Asus ROG STRIX GL502V Motherboard Replacement, Connectors: Schritt 9, Bild 1 von 1
    • Antenna (orange)
    • Speakers (yellow)
    • Power and miscellaneous LED (blue)
    • Keyboard (green)
    • Display (pink)
  10. Asus ROG STRIX GL502V Motherboard Replacement, Remove speaker connector: Schritt 10, Bild 1 von 2 Asus ROG STRIX GL502V Motherboard Replacement, Remove speaker connector: Schritt 10, Bild 2 von 2
    • Remove speaker connector by pulling it out.
  11. Asus ROG STRIX GL502V Motherboard Replacement, Remove keyboard connector: Schritt 11, Bild 1 von 3 Asus ROG STRIX GL502V Motherboard Replacement, Remove keyboard connector: Schritt 11, Bild 2 von 3 Asus ROG STRIX GL502V Motherboard Replacement, Remove keyboard connector: Schritt 11, Bild 3 von 3
    • Lift locking mechanism up
    • Pull ribbon cable from connector
  12. Asus ROG STRIX GL502V Motherboard Replacement, Remove miscellanious connectors: Schritt 12, Bild 1 von 2 Asus ROG STRIX GL502V Motherboard Replacement, Remove miscellanious connectors: Schritt 12, Bild 2 von 2
    • Lift locking tab on each connector (3x)
    • Pull each ribbon cable out
  13. Asus ROG STRIX GL502V Motherboard Replacement, Display cable: Schritt 13, Bild 1 von 3 Asus ROG STRIX GL502V Motherboard Replacement, Display cable: Schritt 13, Bild 2 von 3 Asus ROG STRIX GL502V Motherboard Replacement, Display cable: Schritt 13, Bild 3 von 3
    • Remove screw holding display cable
    • Remove plastic shield over display cable
    • Pull cable out of the clip
  14. Asus ROG STRIX GL502V Motherboard Replacement, Display connector: Schritt 14, Bild 1 von 2 Asus ROG STRIX GL502V Motherboard Replacement, Display connector: Schritt 14, Bild 2 von 2
    • Pull display connector straight up by the pull strap
  15. Asus ROG STRIX GL502V Motherboard Replacement, Antenna connector: Schritt 15, Bild 1 von 3 Asus ROG STRIX GL502V Motherboard Replacement, Antenna connector: Schritt 15, Bild 2 von 3 Asus ROG STRIX GL502V Motherboard Replacement, Antenna connector: Schritt 15, Bild 3 von 3
    • Carefully holding by metal part pull connector up.
    • Repeat for second connector.
  16. Asus ROG STRIX GL502V Motherboard Replacement, Antenna connector cable: Schritt 16, Bild 1 von 2 Asus ROG STRIX GL502V Motherboard Replacement, Antenna connector cable: Schritt 16, Bild 2 von 2
    • Move connector out of the guide.
  17. Asus ROG STRIX GL502V Motherboard Replacement, Hinges screws: Schritt 17, Bild 1 von 2 Asus ROG STRIX GL502V Motherboard Replacement, Hinges screws: Schritt 17, Bild 2 von 2
    • Remove remaining hinges screws (5)
    • Note: one screw was holding display cable.
  18. Asus ROG STRIX GL502V Motherboard Replacement, Lift Hinghes: Schritt 18, Bild 1 von 2 Asus ROG STRIX GL502V Motherboard Replacement, Lift Hinghes: Schritt 18, Bild 2 von 2
    • Lift left hinge up.
    • Lift right hinge up.
  19. Asus ROG STRIX GL502V Motherboard Replacement, Motherboard screws: Schritt 19, Bild 1 von 1
    • Remove two side motherboard screws (yellow marks)
    • Remove 4 center screws (green marks)
    • Note: side screws silver and slighter longer.
  20. Asus ROG STRIX GL502V Motherboard Replacement, Remove motherboard: Schritt 20, Bild 1 von 3 Asus ROG STRIX GL502V Motherboard Replacement, Remove motherboard: Schritt 20, Bild 2 von 3 Asus ROG STRIX GL502V Motherboard Replacement, Remove motherboard: Schritt 20, Bild 3 von 3
    • NOTE: Headset connector is holding in the case.
    • Lift motherboard from HDMI connector side and pull towards it.
  21. Asus ROG STRIX GL502V Motherboard Replacement, Remove fans, heat sink and radio module: Schritt 21, Bild 1 von 1
    • Remove radio module screw (red) and pull it out of connector.
    • Disconnect fans connectors and remove 6x screws. Pull fans out.
    • Remove 8 screws from heat sink and remove it.
    • Note: heat sink use thermal paste on CPU and GPU - you will need to clean and use new before putting it together.
Abschluss
Sergei
650 Reputation
5 Anleitungen geschrieben
Ein Kommentar
Hello I am interested motherboard, how much it's the price ?
Leonard Cristian - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 23
Letzte 30 Tage: 74
Insgesamt: 1,167
