Einleitung
This guide will show you how to replace a switch on the Asus ROG Spatha. For this fix you will need a replacement switch and a Torx T10 screwdriver. This repair is relatively easy to do and will take you about 10 to 15 minutes. This repair will allow you to reuse your mouse for another rated 50 million clicks, expanding the life of the mouse by quite a long time.
Was du brauchst
If the green is visible like in the first photo, turn the switch to fully power down the device.
After locating which switch you need to replace, grab the switch by the top and the bottom and carefully pull it out of the device.
