Zum Hauptinhalt wechseln
Asus ROG Strix GL702VM-BHI7N09 Trackpad Replacement
Was du brauchst
  1. Asus ROG Strix GL702VM-BHI7N09 Trackpad Replacement, Back Panel: Schritt 1, Bild 1 von 2 Asus ROG Strix GL702VM-BHI7N09 Trackpad Replacement, Back Panel: Schritt 1, Bild 2 von 2
    • Flip the laptop over to the back panel, with the serial numbers facing up.
    • Using a Phillips #1 screwdriver, remove the ten 12 mm screws from the back panel.
  2. Asus ROG Strix GL702VM-BHI7N09 Trackpad Replacement: Schritt 2, Bild 1 von 3 Asus ROG Strix GL702VM-BHI7N09 Trackpad Replacement: Schritt 2, Bild 2 von 3 Asus ROG Strix GL702VM-BHI7N09 Trackpad Replacement: Schritt 2, Bild 3 von 3
    • The snap seals don't need a lot of pressure to open, and may break if forced. Be gentle with the opening tool.
    • Wedge the sharp edge of the plastic opening tool into the seam between the back panel and the rest of the laptop, then gently pry the panel up.
    • There will be a snapping sound as you remove the back panel, but that is just the seal loosening.
    • Continue breaking the seals by sliding the plastic opening tool around the entire laptop under the seam until the back panel is free.
    • Once you have broken all the seals, carefully lift the panel off.
  3. Asus ROG Strix GL702VM-BHI7N09 Trackpad Replacement, Battery: Schritt 3, Bild 1 von 1
    • Unplug the battery from the motherboard.
  4. Asus ROG Strix GL702VM-BHI7N09 Trackpad Replacement: Schritt 4, Bild 1 von 3 Asus ROG Strix GL702VM-BHI7N09 Trackpad Replacement: Schritt 4, Bild 2 von 3 Asus ROG Strix GL702VM-BHI7N09 Trackpad Replacement: Schritt 4, Bild 3 von 3
    • Unscrew the 3.8 mm Phillips #1 screw on the top right hand corner of the battery.
    • Lift battery from laptop frame.
  5. Asus ROG Strix GL702VM-BHI7N09 Trackpad Replacement, Hard Drive: Schritt 5, Bild 1 von 1
    • Using a Phillips #1 screwdriver, remove the four 4 mm screws holding the hard drive.
  6. Asus ROG Strix GL702VM-BHI7N09 Trackpad Replacement: Schritt 6, Bild 1 von 1
    • Pull the hard drive directly away from the fan just above it.
    • The connecting pins should slide out easily, but you might have to move the hard drive around a bit to loosen the pins.
  7. Asus ROG Strix GL702VM-BHI7N09 Trackpad Replacement, Fan: Schritt 7, Bild 1 von 1
    • Using a Phillips #1 screwdriver, remove the four indicated 4 mm screws that hold the black fan and the silver one adjacent to it.
  8. Asus ROG Strix GL702VM-BHI7N09 Trackpad Replacement: Schritt 8, Bild 1 von 1
    • The smaller black fan must be removed before the larger gray fan on the right can be taken out.
    • To remove the black fan, pull gently on the connecting cables outlined.
  9. Asus ROG Strix GL702VM-BHI7N09 Trackpad Replacement: Schritt 9, Bild 1 von 1
    • Unplug the white connector by gently pulling the cables.
    • Lift off the gray fan.
  10. Asus ROG Strix GL702VM-BHI7N09 Trackpad Replacement: Schritt 10, Bild 1 von 1
    • Using a Phillips #1 screwdriver, remove the two indicated 4 mm screws from the other gray fan.
  11. Asus ROG Strix GL702VM-BHI7N09 Trackpad Replacement: Schritt 11, Bild 1 von 3 Asus ROG Strix GL702VM-BHI7N09 Trackpad Replacement: Schritt 11, Bild 2 von 3 Asus ROG Strix GL702VM-BHI7N09 Trackpad Replacement: Schritt 11, Bild 3 von 3
    • Unplug the white connector by gently pulling it towards the center of the computer.
    • Lift the fan out of the body of the laptop to remove it.
  12. Asus ROG Strix GL702VM-BHI7N09 Trackpad Replacement, Motherboard: Schritt 12, Bild 1 von 3 Asus ROG Strix GL702VM-BHI7N09 Trackpad Replacement, Motherboard: Schritt 12, Bild 2 von 3 Asus ROG Strix GL702VM-BHI7N09 Trackpad Replacement, Motherboard: Schritt 12, Bild 3 von 3
    • Disconnect the speakers connectors located in each of the bottom corners.
    • Gently pull the wire up from the motherboard.
    • Once the wire is disconnected, pull the speaker out.
  13. Asus ROG Strix GL702VM-BHI7N09 Trackpad Replacement: Schritt 13, Bild 1 von 3 Asus ROG Strix GL702VM-BHI7N09 Trackpad Replacement: Schritt 13, Bild 2 von 3 Asus ROG Strix GL702VM-BHI7N09 Trackpad Replacement: Schritt 13, Bild 3 von 3
    • Gently lift the graphics card from the motherboard.
  14. Asus ROG Strix GL702VM-BHI7N09 Trackpad Replacement: Schritt 14, Bild 1 von 2 Asus ROG Strix GL702VM-BHI7N09 Trackpad Replacement: Schritt 14, Bild 2 von 2
    • Use reverse pliers to detach ribbon connectors from the motherboard.
  15. Asus ROG Strix GL702VM-BHI7N09 Trackpad Replacement: Schritt 15, Bild 1 von 3 Asus ROG Strix GL702VM-BHI7N09 Trackpad Replacement: Schritt 15, Bild 2 von 3 Asus ROG Strix GL702VM-BHI7N09 Trackpad Replacement: Schritt 15, Bild 3 von 3
    • Remove each of the 4.7 mm Phillips #1 screws marked by a white arrow on the motherboard.
    • Remove the 6.7 mm Phillips #1 screws from the metal latches on the hinge-side corners.
    • The 4.7 mm Phillips #1 screw on the far left of the motherboard is covered by the black connecting wire in Step 5.
  16. Asus ROG Strix GL702VM-BHI7N09 Trackpad Replacement: Schritt 16, Bild 1 von 3 Asus ROG Strix GL702VM-BHI7N09 Trackpad Replacement: Schritt 16, Bild 2 von 3 Asus ROG Strix GL702VM-BHI7N09 Trackpad Replacement: Schritt 16, Bild 3 von 3
    • Gently pull on black connecting wire to disconnect the monitor screen from the motherboard.
    • This will uncover the far left 4.7 mm Phillips #1 screw.
  17. Asus ROG Strix GL702VM-BHI7N09 Trackpad Replacement: Schritt 17, Bild 1 von 3 Asus ROG Strix GL702VM-BHI7N09 Trackpad Replacement: Schritt 17, Bild 2 von 3 Asus ROG Strix GL702VM-BHI7N09 Trackpad Replacement: Schritt 17, Bild 3 von 3
    • Lift the metal latches on both sides.
    • This can be easily done by opening the laptop after the metal latch screws have been removed.
  18. Asus ROG Strix GL702VM-BHI7N09 Trackpad Replacement: Schritt 18, Bild 1 von 1
    • Remove the motherboard from the laptop frame.
    • You will need to pull the motherboard to the side as well as lifting it to free its various ports from the sides of the laptop case.
    • There is adhesive attaching the final ribbon connector to the bottom of the motherboard. This will need to be removed.
  19. Asus ROG Strix GL702VM-BHI7N09 Trackpad Replacement, Trackpad: Schritt 19, Bild 1 von 3 Asus ROG Strix GL702VM-BHI7N09 Trackpad Replacement, Trackpad: Schritt 19, Bild 2 von 3 Asus ROG Strix GL702VM-BHI7N09 Trackpad Replacement, Trackpad: Schritt 19, Bild 3 von 3
    • Ensure the ribbon cables on the trackpad are disconnected.
    • Using a Phillips #1 screwdriver, remove the three 4mm retaining screws.
    • Gently lift and slide the track pad out of the mount.
    • It may help to lift the trackpad from the underside near the keyboard.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 7
Insgesamt: 657
