Einleitung
This is a step by step process for the replacement or repair of the webcam on your Asus ROG Strix GL702VS laptop. If you are experiencing bad quality or a black screen while using the webcam, follow these steps to remove the webcam and replace it.
Was du brauchst
Remove the two screw stickers at the bottom corners of the screen.
Remove the two 4mm JIS #0 screws beneath the stickers.
Break the glue between the bezel and screen with a nylon spudger, working around the inside of the bezel.
Using an opening tool, lift up the bezel once the glue has been removed.
Remove the four interior 4mm JIS #0 screws from each of the four metal LCD tabs.
On the backside of the LCD, disconnect the LCD cable using a pair of tweezers.
Once fully disconnected, remove the LCD and replace it.
Gently lift the webcam out of its resting position at the top of the LCD assembly.
Using the nylon tweezers or your hand, disconnect the webcam module.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
