Zum Hauptinhalt wechseln
Asus ROG Strix GL702VS Webcam Replacement
Was du brauchst
    1. Asus ROG Strix GL702VS Webcam Replacement, LCD Screen (Display): Schritt 1, Bild 1 von 3 Asus ROG Strix GL702VS Webcam Replacement, LCD Screen (Display): Schritt 1, Bild 2 von 3 Asus ROG Strix GL702VS Webcam Replacement, LCD Screen (Display): Schritt 1, Bild 3 von 3
      • Remove the two screw stickers at the bottom corners of the screen.
      • Remove the two 4mm JIS #0 screws beneath the stickers.
      Frag FixBot
      Kommentar hinzufügen
    2. Asus ROG Strix GL702VS Webcam Replacement: Schritt 2, Bild 1 von 3 Asus ROG Strix GL702VS Webcam Replacement: Schritt 2, Bild 2 von 3 Asus ROG Strix GL702VS Webcam Replacement: Schritt 2, Bild 3 von 3
      • Break the glue between the bezel and screen with a nylon spudger, working around the inside of the bezel.
      • Using an opening tool, lift up the bezel once the glue has been removed.
      • The plastic clips remain so it will have some resistance/snapping noises.
      Frag FixBot
    3. Asus ROG Strix GL702VS Webcam Replacement: Schritt 3, Bild 1 von 2 Asus ROG Strix GL702VS Webcam Replacement: Schritt 3, Bild 2 von 2
      • Lift the plastic bezel off of the front display panel.
      • The plastic bezel will click when put back on the screen.
      Frag FixBot
    4. Asus ROG Strix GL702VS Webcam Replacement: Schritt 4, Bild 1 von 1
      • Remove the four interior 4mm JIS #0 screws from each of the four metal LCD tabs.
      Frag FixBot
    5. Asus ROG Strix GL702VS Webcam Replacement: Schritt 5, Bild 1 von 3 Asus ROG Strix GL702VS Webcam Replacement: Schritt 5, Bild 2 von 3 Asus ROG Strix GL702VS Webcam Replacement: Schritt 5, Bild 3 von 3
      • Once the LCD display is freed you can lift it up out of the casing.
      • Be careful as the cable remains attached.
      Frag FixBot
    6. Asus ROG Strix GL702VS Webcam Replacement: Schritt 6, Bild 1 von 2 Asus ROG Strix GL702VS Webcam Replacement: Schritt 6, Bild 2 von 2
      In diesem Schritt verwendetes Werkzeug:
      • On the backside of the LCD, disconnect the LCD cable using a pair of tweezers.
      • Once fully disconnected, remove the LCD and replace it.
      Frag FixBot
    1. Asus ROG Strix GL702VS Webcam Replacement, Webcam: Schritt 7, Bild 1 von 1
      • Gently lift the webcam out of its resting position at the top of the LCD assembly.
      Frag FixBot
    2. Asus ROG Strix GL702VS Webcam Replacement: Schritt 8, Bild 1 von 2 Asus ROG Strix GL702VS Webcam Replacement: Schritt 8, Bild 2 von 2
      • Using the nylon tweezers or your hand, disconnect the webcam module.
      Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 30
Insgesamt: 838
