Zum Hauptinhalt wechseln
Asus ROG Strix X570-I Mini ITX Motherboard M.2 SSD Replacement
Was du brauchst
  1. Asus ROG Strix X570-I Mini ITX Motherboard M.2 SSD Replacement, Front Side M.2 SSD: Schritt 1, Bild 1 von 2 Asus ROG Strix X570-I Mini ITX Motherboard M.2 SSD Replacement, Front Side M.2 SSD: Schritt 1, Bild 2 von 2
    • Remove the front panel.
    • This may involve one or two thumb screws depending on your case.
  2. Asus ROG Strix X570-I Mini ITX Motherboard M.2 SSD Replacement: Schritt 2, Bild 1 von 1
    • Detach the PSU cable from your graphics card.
  3. Asus ROG Strix X570-I Mini ITX Motherboard M.2 SSD Replacement: Schritt 3, Bild 1 von 3 Asus ROG Strix X570-I Mini ITX Motherboard M.2 SSD Replacement: Schritt 3, Bild 2 von 3 Asus ROG Strix X570-I Mini ITX Motherboard M.2 SSD Replacement: Schritt 3, Bild 3 von 3
    • Unscrew the back panel screws to release the graphics card.
    • Release the PCIe switch.
    • Be careful when using a tool as you can damage the motherboard if the tool slips.
    • Take the graphics card out vertically.
  4. Asus ROG Strix X570-I Mini ITX Motherboard M.2 SSD Replacement: Schritt 4, Bild 1 von 3 Asus ROG Strix X570-I Mini ITX Motherboard M.2 SSD Replacement: Schritt 4, Bild 2 von 3 Asus ROG Strix X570-I Mini ITX Motherboard M.2 SSD Replacement: Schritt 4, Bild 3 von 3
    • Unscrew the heat-sink screws.
    • Remove the heat-sink vertically.
    • It is important to remove it vertically as there are pins on the right side that must not be bent.
  5. Asus ROG Strix X570-I Mini ITX Motherboard M.2 SSD Replacement: Schritt 5, Bild 1 von 3 Asus ROG Strix X570-I Mini ITX Motherboard M.2 SSD Replacement: Schritt 5, Bild 2 von 3 Asus ROG Strix X570-I Mini ITX Motherboard M.2 SSD Replacement: Schritt 5, Bild 3 von 3
    • Unscrew the small screw holding the SSD.
    • Remove the SSD at an angle.
    • Be careful to avoid grabbing the SSD from its circuit.
    • Insert a new SSD at a 30-40 degree angle.
Abschluss
7 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 13
Letzte 30 Tage: 78
Insgesamt: 3,800
