Einleitung
This is a comprehensive guide on replacing the battery in your Asus ROG Zephyrus G14 laptop. If your laptop can no longer retain a charge, it is probable that your dealing with a malfunctioning battery that needs to be replaced.
A properly functioning battery is responsible for supplying power to your laptop. As time passes and your laptop's battery undergoes numerous charge cycles, it may exhibit a quicker discharge rate. If you observe that your fully charged battery is depleting more rapidly than usual, it's advisable to perform a battery calibration to ascertain its true charging capacity. However, if you consistently experience substantial reductions in battery percentage, it's a clear indicator that it's time to replace your battery.
If you notice that your battery is swollen, take proper precautions. A punctured battery can cause a dangerous fire.
Before beginning, make sure that you power down your device.
Was du brauchst
Flip laptop so the back cover faces up.
Remove the ten (M2x9) screws.
Remove the three (M2x4.5) screw.
Loosen (M2.5x6) pop-open screw without removing screw from the cover.
Place iFixit opening tool at the pop-open screw (bottom right screw), there will be a gap there to place your tool.
Pry your way around the perimeter of the laptop.
Use the plastic spudger to gently slide back the metal retaining clasp from the connector.
Place your spudger under the connector and carefully pry each side up.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
