Zum Hauptinhalt wechseln
Asus ROG Zephyrus G16 GU603VV SSD Replacement
Was du brauchst
  1. Asus ROG Zephyrus G16 GU603VV SSD Replacement, SSD: Schritt 1, Bild 1 von 1
    • This step can be used as reference for screw locations that secure the bottom panel:
    • Three M2 8 mm screws
    • Two M2 11.5 mm screws
    • Four M2 11 mm screws
    • Three M2 5.5 mm screws
    • One M2 8 mm captive screw
  2. Asus ROG Zephyrus G16 GU603VV SSD Replacement: Schritt 2, Bild 1 von 3 Asus ROG Zephyrus G16 GU603VV SSD Replacement: Schritt 2, Bild 2 von 3 Asus ROG Zephyrus G16 GU603VV SSD Replacement: Schritt 2, Bild 3 von 3
    • Remove the three rubber covers for the middle screws.
    • These rubber covers have a tendency to fly off when being removed.
  3. Asus ROG Zephyrus G16 GU603VV SSD Replacement: Schritt 3, Bild 1 von 3 Asus ROG Zephyrus G16 GU603VV SSD Replacement: Schritt 3, Bild 2 von 3 Asus ROG Zephyrus G16 GU603VV SSD Replacement: Schritt 3, Bild 3 von 3
    • Remove the three 8 mm Phillips screws.
  4. Asus ROG Zephyrus G16 GU603VV SSD Replacement: Schritt 4, Bild 1 von 3 Asus ROG Zephyrus G16 GU603VV SSD Replacement: Schritt 4, Bild 2 von 3 Asus ROG Zephyrus G16 GU603VV SSD Replacement: Schritt 4, Bild 3 von 3
    • Remove the four 11 mm Phillips screws.
    • Remove the center two 11.5 mm Phillips screws.
  5. Asus ROG Zephyrus G16 GU603VV SSD Replacement: Schritt 5, Bild 1 von 3 Asus ROG Zephyrus G16 GU603VV SSD Replacement: Schritt 5, Bild 2 von 3 Asus ROG Zephyrus G16 GU603VV SSD Replacement: Schritt 5, Bild 3 von 3
    • Remove the bottom three 5.5 mm Phillips screws.
    • The bottom right screw is not removed during this step.
  6. Asus ROG Zephyrus G16 GU603VV SSD Replacement: Schritt 6, Bild 1 von 3 Asus ROG Zephyrus G16 GU603VV SSD Replacement: Schritt 6, Bild 2 von 3 Asus ROG Zephyrus G16 GU603VV SSD Replacement: Schritt 6, Bild 3 von 3
    • Loosen the 8 mm Phillips captive screw in the bottom right corner.
    • The screw will not be removed entirely; it is a captive screw.
  7. Asus ROG Zephyrus G16 GU603VV SSD Replacement: Schritt 7, Bild 1 von 3 Asus ROG Zephyrus G16 GU603VV SSD Replacement: Schritt 7, Bild 2 von 3 Asus ROG Zephyrus G16 GU603VV SSD Replacement: Schritt 7, Bild 3 von 3
    • Shimmy your pick into the seam opened up by loosening the retaining screw.
    • Gently move your pick clockwise around the edge of the device in the seam between the cover and the laptop to loosen the cover plate.
  8. Asus ROG Zephyrus G16 GU603VV SSD Replacement: Schritt 8, Bild 1 von 3 Asus ROG Zephyrus G16 GU603VV SSD Replacement: Schritt 8, Bild 2 von 3 Asus ROG Zephyrus G16 GU603VV SSD Replacement: Schritt 8, Bild 3 von 3
    • Gently remove the lower case.
  9. Asus ROG Zephyrus G16 GU603VV SSD Replacement: Schritt 9, Bild 1 von 3 Asus ROG Zephyrus G16 GU603VV SSD Replacement: Schritt 9, Bild 2 von 3 Asus ROG Zephyrus G16 GU603VV SSD Replacement: Schritt 9, Bild 3 von 3
    • Slide the battery connector latch upwards to free the battery cable for removal.
  10. Asus ROG Zephyrus G16 GU603VV SSD Replacement: Schritt 10, Bild 1 von 2 Asus ROG Zephyrus G16 GU603VV SSD Replacement: Schritt 10, Bild 2 von 2
    • Remove the battery connector by lifting it up and away from the board.
  11. Asus ROG Zephyrus G16 GU603VV SSD Replacement: Schritt 11, Bild 1 von 3 Asus ROG Zephyrus G16 GU603VV SSD Replacement: Schritt 11, Bild 2 von 3 Asus ROG Zephyrus G16 GU603VV SSD Replacement: Schritt 11, Bild 3 von 3
    • Lift the right edge of the protective thermal pad on top of the old SSD and remove the screw underneath.
    • Disconnect the SSD by gently pushing it to the right.
    • Remove the SSD.
  12. Asus ROG Zephyrus G16 GU603VV SSD Replacement: Schritt 12, Bild 1 von 2 Asus ROG Zephyrus G16 GU603VV SSD Replacement: Schritt 12, Bild 2 von 2
    • Insert the replacement SSD and screw it into place.
Abschluss
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
2 weitere Personen haben diese Anleitung absolviert.
Anusheel
229 Reputation
1 Anleitung geschrieben
UC Davis, Team 1-2, Morris Winter 2024 Mitglied von UC Davis, Team 1-2, Morris Winter 2024
UCD-MORRIS-W24S1G2
3 Mitglieder
2 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 75
Letzte 30 Tage: 308
Insgesamt: 8,202
