Zum Hauptinhalt wechseln
Asus ROG Zephyrus M15 GU502L Touchpad Replacement
Was du brauchst
  1. Asus ROG Zephyrus M15 GU502L Touchpad Replacement, Battery: Schritt 1, Bild 1 von 2 Asus ROG Zephyrus M15 GU502L Touchpad Replacement, Battery: Schritt 1, Bild 2 von 2
    • Remove fifteen 10 mm screws from the bottom cover using a Phillips #0 screwdriver.
  2. Asus ROG Zephyrus M15 GU502L Touchpad Replacement: Schritt 2, Bild 1 von 2 Asus ROG Zephyrus M15 GU502L Touchpad Replacement: Schritt 2, Bild 2 von 2
    • Use a plastic opening tool to separate the back cover from the laptop.
    • It is recommended that you separate the laptop cover from the side and run the tool along the edge of the cover to open it.
    • Be careful not to damage the cover when removing it from the laptop.
  3. Asus ROG Zephyrus M15 GU502L Touchpad Replacement: Schritt 3, Bild 1 von 1
    • Remove six 4.8 mm screws that secure the battery using a Phillips #00 screwdriver.
  4. Asus ROG Zephyrus M15 GU502L Touchpad Replacement: Schritt 4, Bild 1 von 2 Asus ROG Zephyrus M15 GU502L Touchpad Replacement: Schritt 4, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • Disconnect the 8-pin battery that secures the battery to the motherboard.
    • Use the nylon tipped reverse tweezers to squeeze the edges, then pull out the connector.
  5. Asus ROG Zephyrus M15 GU502L Touchpad Replacement: Schritt 5, Bild 1 von 1
    • Remove the battery from the computer.
  6. Asus ROG Zephyrus M15 GU502L Touchpad Replacement, Touchpad: Schritt 6, Bild 1 von 1
    • Remove the 3mm screws that secure the touchpad using a Phillips #0 screwdriver.
  7. Asus ROG Zephyrus M15 GU502L Touchpad Replacement: Schritt 7, Bild 1 von 1
    • Remove the touch pad from the casing.
    • Be cautious picking up the touch pad as it is light.
Abschluss
Yahir Donis
339 Reputation
2 Anleitungen geschrieben
Gateway, Team 69-69, Gonzalez Fall 2023 Mitglied von Gateway, Team 69-69, Gonzalez Fall 2023
GCC-GONZALEZ-F23S69G69
4 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 21
Insgesamt: 291
