Einleitung
The Asus RT-N56U Wireless Router was released in Early 2011. It featured both 2.4GHz and 5GHz wireless networking, 2 USB 2.0 Ports, 4 Ethernet Ports, and a thin & stylish design!
Was du brauchst
Remove the adhesive and clips also securing the front casing and lift it like a book from the left side, then remove it.
Remove the 2 Phillips screws securing the main board to the casing.
Lift to around a 20° angle.
Gently pull up slightly, then the board should unlock to allow you to rotate it to around a 90° angle and remove it.
