Zum Hauptinhalt wechseln
Asus TUF Gaming FX705G Fan Replacement
Was du brauchst
  1. Asus TUF Gaming FX705G Fan Replacement, Back Cover: Schritt 1, Bild 1 von 2 Asus TUF Gaming FX705G Fan Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Remove the eleven Phillips #0 screws that secure the back cover.
  2. Asus TUF Gaming FX705G Fan Replacement: Schritt 2, Bild 1 von 2 Asus TUF Gaming FX705G Fan Replacement: Schritt 2, Bild 2 von 2
    • Use the iFixit opening tool to lift the back cover's seam, then insert the spudger parallel to the back cover and lift gently upward.
    • You will hear pops as the back cover releases.
  3. Asus TUF Gaming FX705G Fan Replacement, Battery: Schritt 3, Bild 1 von 2 Asus TUF Gaming FX705G Fan Replacement, Battery: Schritt 3, Bild 2 von 2
    • Remove the three Phillips #00 screws from the battery housing.
  4. Asus TUF Gaming FX705G Fan Replacement: Schritt 4, Bild 1 von 2 Asus TUF Gaming FX705G Fan Replacement: Schritt 4, Bild 2 von 2
    • Disconnect the wire from the motherboard, and lift the battery from its housing.
  5. Asus TUF Gaming FX705G Fan Replacement, Fan: Schritt 5, Bild 1 von 2 Asus TUF Gaming FX705G Fan Replacement, Fan: Schritt 5, Bild 2 von 2
    • Remove the five Phillips #00 screws from the fan casings.
    • The left fan has three screws and the right fan has two screws.
  6. Asus TUF Gaming FX705G Fan Replacement: Schritt 6, Bild 1 von 3 Asus TUF Gaming FX705G Fan Replacement: Schritt 6, Bild 2 von 3 Asus TUF Gaming FX705G Fan Replacement: Schritt 6, Bild 3 von 3
    • Unplug the cables that connect the fan to the motherboard.
  7. Asus TUF Gaming FX705G Fan Replacement: Schritt 7, Bild 1 von 3 Asus TUF Gaming FX705G Fan Replacement: Schritt 7, Bild 2 von 3 Asus TUF Gaming FX705G Fan Replacement: Schritt 7, Bild 3 von 3
    • Lift the motherboard to unclip the housing clip on the back of the fan.
    • Remove the fan.
Abschluss
17 weitere Personen haben diese Anleitung absolviert.
3 Kommentare zur Anleitung
A bit nerve-racking, but got the new CPU fan installed, seems to be working fine according to armory crate. I did note that the CPU fan plug was quite stiff but I did manage to carefully wiggle it out. Anyways found your instructions very helpful especially the pics.
Thank You.
1857classic - Antwort Teilen
Is it possible to change the cpu an gpu I'm a noob for sure thanks
Like to change them to make it a better pc might not be able to FX705DY
Christopher Hall - Antwort Teilen
This was very helpful. Thank you
Sue Olmos - Antwort Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 19
Letzte 30 Tage: 72
Insgesamt: 17,533
